Home » Language IDEs » ServerTools (WTP) » Problems debugging a WAR with Tomcat
Problems debugging a WAR with Tomcat [message #231720] |
Thu, 21 May 2009 07:22  |
I'm not sure if this is the correct place to post this topic, but since I
can't find any other more suitable I'll do it here. Please point me the
right place if I'm wrong.
My problem is as follows. I'm working in a Web Project using Eclipse 3.4.1
and Tomcat 6, I don't think I'm using WTP at the moment, I just downloaded
Eclipse 3.4.1 and Tomcat individually. I compile, execute and deploy with
an build.xml file. The problem arises when I try to debug the WAR file
once imported. It seems that Tomcat never really "starts" when I launch
Debug as-> Debug on Server. Once the timeout expires, the tomcat thread is
terminated along the debug processing. Obviously, I could increase the
timeout setting, but that seems too nasty...I used Glassfish before and I
could debug with no probs, but due project features, I had to swap to
Tomcat, and I can't debug with it...
Any help will be very appreciated, it's hard to believe no one encountered
this problem before me...I checked many other forums and they all propose
the use of the Sydeo Plugin but that's unnecessary in my case.
Alejandro
Re: Problems debugging a WAR with Tomcat [message #231730 is a reply to message #231720] |
Thu, 21 May 2009 09:03   |
Using "Debug on Server" implies you are using WTP. Likely you
downloaded the Java EE package of Eclipse which includes WTP.
Just saying it times out doesn't provide much in the way clues as to
what is different about your circumstances that is causing the problem.
Does Run -> Run on Server behave the same or different? What, if
anything, appears in the Console view when you attempt to start Tomcat
in debug or run mode? What OS are you running on? Was this Tomcat
customized before creating the runtime and server from it in Eclipse, or
did it still have it's default settings?
Feel free to examine the Tomcat FAQ[1] for information about the Tomcat
support in WTP. However, I don't think any of the trouble shooting
questions refers to a timeout problem.
Larry
[1] http://wiki.eclipse.org/WTP_Tomcat_FAQ
Alejandro wrote:
> I can't find any other more suitable I'll do it here. Please point me
> the right place if I'm wrong.
> 3.4.1 and Tomcat 6, I don't think I'm using WTP at the moment, I just
> downloaded Eclipse 3.4.1 and Tomcat individually. I compile, execute and
> deploy with an build.xml file. The problem arises when I try to debug
> the WAR file once imported. It seems that Tomcat never really "starts"
> when I launch Debug as-> Debug on Server. Once the timeout expires, the
> tomcat thread is terminated along the debug processing. Obviously, I
> could increase the timeout setting, but that seems too nasty...I used
> Glassfish before and I could debug with no probs, but due project
> features, I had to swap to Tomcat, and I can't debug with it...
> encountered this problem before me...I checked many other forums and
> they all propose the use of the Sydeo Plugin but that's unnecessary in
> my case.
> Best regards,
> Alejandro
Re: Problems debugging a WAR with Tomcat [message #231736 is a reply to message #231730] |
Thu, 21 May 2009 10:01   |
Hi Larry, thanks for your quick response.
I will try to answer your questions:
Nope, in that case, Tomcat starts with no problem and I can try my web
application with no probs
Windows XP SP3, no firewall, no anti-virus enabled. As I mentioned on the
previous post, before trying Tomcat, I used Glassfish v3 and it worked
great, no problems at all.
Was this Tomcat customized before creating the runtime and server from it
in Eclipse, or did it still have it's default settings?
Fresh install and default settings for Tomcat. Only changed the port to
80. Only thing I changed (as I saw someone mention it is required for
debugging) is that I let Eclipse take control of the Tomcat instalation,
and checked the "Never publish automatically" checkbox. Besides that,
nothing has changed.
Towards the console output when I try to debug on Tomcat:
1-may-2009 14:54:53 org.apache.tomcat.util.digester.SetPropertiesRule begin
ADVERTENCIA: [SetPropertiesRule]{Server/Service/Engine/Host/Context}
Setting property 'source' to 'org.eclipse.jst.j2ee.server:UCH' did not
find a matching property.
21-may-2009 14:54:53 org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path:
C:\Sun\SDK\jdk\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\syst em32;C:\WINDOWS;C:\Sun\SDK\jdk\jre\bin;C:/Sun/SDK/jdk/bin/.. /jre/bin/client;C:/Sun/SDK/jdk/bin/../jre/bin;C:\WINDOWS\sys tem32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Sun\SDK\jdk\bin ;C:\Archivos
de programa\TortoiseSVN\bin;C:\Sun\SDK\jdk\bin
21-may-2009 14:54:53 org.apache.coyote.http11.Http11Protocol init
INFO: Inicializando Coyote HTTP/1.1 en puerto http-80
21-may-2009 14:54:53 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 946 ms
21-may-2009 14:54:53 org.apache.catalina.core.StandardService start
INFO: Arrancando servicio Catalina
21-may-2009 14:54:53 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
edu.wisc.trace.uch.UCH.<init> (Line: 135)
INFO: IP Address =172.22.50.20
I can debug until the timeout expires...then the thread is killed. I tried
to look on the Tomcat/logs for a recent log but the newest is from
yesterday...the previous was the console output.
Thanks in advance...this is puzzling me...
Re: Problems debugging a WAR with Tomcat [message #231745 is a reply to message #231736] |
Thu, 21 May 2009 10:53   |
When starting the Tomcat server, there is a "ping" thread started that
tries to establish a connection to Tomcat. When that succeeds, the
Servers view transitions that Tomcat server from "starting" to "started"
or "debugging". If "ping" doesn't succeed within the timeout, it
assumes startup failed and it kills the Tomcat process. I don't have
any explanation as to why Run on Server succeeds and Debug doesn't.
I recommend the following to gather more clues. Unzip the Tomcat binary
into a new directory to get a fresh default copy. Create a new Tomcat
runtime and server from that fresh Tomcat. Try Debug on Server and Run
on Server and see what happens. Hopefully this will tell us if there is
something different about your system that is triggering this behavior,
or it's something about changes to the Tomcat configuration.
Note, selecting "Use Tomcat installation..." is not in any way required
for debugging. How to best configure things for debugging kind of
depends on exactly what you mean by debugging and how badly you want to
avoid restarts.
Larry
> the previous post, before trying Tomcat, I used Glassfish v3 and it
> worked great, no problems at all.
> it in Eclipse, or did it still have it's default settings?
> java.library.path:
> tried to look on the Tomcat/logs for a recent log but the newest is from
Re: Problems debugging a WAR with Tomcat [message #231778 is a reply to message #231745] |
Fri, 22 May 2009 05:17   |
> avoid restarts.
> Cheers,
> Larry
>> java.library.path:
C:SunSDKjdkbin;.;C:WINDOWSSunJavabin;C:WINDOWSsystem32;C:WIN DOWS;C:SunSDKjdkjrebin;C:/Sun/SDK/jdk/bin/../jre/bin/client; C:/Sun/SDK/jdk/bin/../jre/bin;C:WINDOWSsystem32;C:WINDOWS;C: WINDOWSSystem32Wbem;C:SunSDKjdkbin;C:Archivos
>> de programaTortoiseSVNbin;C:SunSDKjdkbin
Hi again Larry,
I tried to download the binaries and add a new Tomcat runtime server
config but no luck, I couldn't make it even start...So I unisntalled
everything and started from scratch...and I can debug now! No timeout
expires notification! Which is good, I can run and debug now with no
issues. The only thing...I keep on getting a NullPointer Exception
whenever I click on the Tomcat Server on the Servers view...below you can
find the error log:
eclipse.buildId=M20080911-1700
java.version=1.6.0_10
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri May 22 10:05:28 CEST 2009
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
at
com.sun.enterprise.jst.server.sunappsrv.actions.OpenBrowserA ction.accept(OpenBrowserAction.java:66)
at
com.sun.enterprise.jst.server.sunappsrv.actions.AppServerCon textAction.selectionChanged(AppServerContextAction.java:229)
at
org.eclipse.ui.actions.SelectionProviderAction.selectionChan ged(SelectionProviderAction.java:143)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2062)
at
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1638)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer .java:1104)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:39 2)
at
org.eclipse.wst.server.ui.internal.view.servers.ServerTableV iewer$7.run(ServerTableViewer.java:463)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
As far as I'm concerned this is not affecting Tomcat in any way, it's just
an annoying thing that keeps on popping up a window.
Best regards and many thanks for your advices
Alejandro
Re: Problems debugging a WAR with Tomcat [message #231794 is a reply to message #231778] |
Fri, 22 May 2009 09:15  |
>> binary into a new directory to get a fresh default copy. Create a new
>> Tomcat runtime and server from that fresh Tomcat. Try Debug on Server
>> and Run on Server and see what happens. Hopefully this will tell us
>> if there is something different about your system that is triggering
>> this behavior, or it's something about changes to the Tomcat
>> configuration.
>> required for debugging. How to best configure things for debugging
>> kind of depends on exactly what you mean by debugging and how badly
>> you want to avoid restarts.
>> Cheers,
>> Larry
>>> web application with no probs
>>> from it in Eclipse, or did it still have it's default settings?
>>> to 80. Only thing I changed (as I saw someone mention it is required
>>> for debugging) is that I let Eclipse take control of the Tomcat
>>> instalation, and checked the "Never publish automatically" checkbox.
>>> Besides that, nothing has changed.
>>> begin
>>> not find a matching property.
>>> java.library.path:
>>> from yesterday...the previous was the console output.
> Hi again Larry,
> can find the error log:
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> just an annoying thing that keeps on popping up a window.
> Alejandro
I would guess that "com.sun.enterprise.jst.server.sunappsrv" in the
package suggests the NPE is coming from some Glassfish plug-in.
Larry
Current Time: Fri Jul 25 21:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.06698 seconds
