Home » Language IDEs » C / C++ IDE (CDT) » exception while checking CDT 5.0.2
exception while checking CDT 5.0.2 [message #230929] Sun, 01 March 2009 11:10 Go to next message
I installed eclipse 3.4.2 (Build id: M20090211-1700) and 5.0.2 (RC2).
After creating new C++ project and linking source folder. I restarted
eclipse and saw the following exceptions (it is the same exception twice):
1)
Sun Mar 01 17:02:57 IST 2009
An exception occurred during console notification
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.widgets.Display.error(Display.java:1142)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:665)
at
org.eclipse.ui.internal.console.ConsoleDropDownAction.consol esRemoved(ConsoleDropDownAction.java:150)
at
org.eclipse.ui.internal.console.ConsoleManager$ConsoleNotifi er.run(ConsoleManager.java:154)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.ui.internal.console.ConsoleManager$ConsoleNotifi er.notify(ConsoleManager.java:174)
at
org.eclipse.ui.internal.console.ConsoleManager.fireUpdate(Co nsoleManager.java:262)
at
org.eclipse.ui.internal.console.ConsoleManager.removeConsole s(ConsoleManager.java:244)
at
org.eclipse.cdt.internal.ui.buildconsole.BuildConsoleManager .shutdown(BuildConsoleManager.java:163)
at org.eclipse.cdt.ui.CUIPlugin.stop(CUIPlugin.java:537)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1050)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1046)
at
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:457)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:531)
at
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1104)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:655)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:312)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:257)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:236)
at
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:678)
at
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:576)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:424)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:200)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
2)
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.console".
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: exception while checking CDT 5.0.2 [message #230937 is a reply to message #230929] Sun, 01 March 2009 11:16 Go to previous messageGo to next message
Steps to reproduce this behavior:
1) Open eclipse
2) Create Executable Empty Project (Linux GCC)
3) Restart Eclipse
4) Open "Error Log" view
Re: exception while checking CDT 5.0.2 [message #231082 is a reply to message #230937] Tue, 03 March 2009 08:06 Go to previous messageGo to next message
Did anyone encounter this behavior. Should I open a bug?
Re: exception while checking CDT 5.0.2 [message #231542 is a reply to message #231082] Thu, 12 March 2009 10:34 Go to previous messageGo to next message
I have a similar problem on CDT 4.0.3 (Eclipse 3.3) and CDT 5.0.2 (Eclipse
3.4). I use WinXP and Cygwin. I noticed that my .log contains the same
errors.
A simple "Hello world" program that I wrote on Eclipse compiled okay on
both but no output given (on the console) when run on Eclipse (I even
tried to do fflush(stdout), putting "\n", nothing works). The resulting
executable works fine when run on Cygwin console.
Can someone help?
Thank you.
Re: exception while checking CDT 5.0.2 [message #231558 is a reply to message #231542] Thu, 12 March 2009 19:08 Go to previous messageGo to next message
is this the same exception as I described?
Re: exception while checking CDT 5.0.2 [message #231597 is a reply to message #231558] Fri, 13 March 2009 04:47 Go to previous message
I think yes (I did not compare the whole lines but the first few lines) up
to the SafeRunner). Here is the complete log I have:
!ENTRY org.eclipse.ui.console 4 2 2009-03-12 18:15:15.005
!MESSAGE Problems occurred when invoking code from plug-in:
!STACK 0
at org.eclipse.swt.widgets.Display.error(Display.java:1180)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:648)
at
at
at
at
at
at
org.eclipse.debug.internal.ui.views.console.ProcessConsoleMa nager.removeProcess(ProcessConsoleManager.java:98)
at
org.eclipse.debug.internal.ui.views.console.ProcessConsoleMa nager.removeLaunch(ProcessConsoleManager.java:81)
at
org.eclipse.debug.internal.ui.views.console.ProcessConsoleMa nager.shutdown(ProcessConsoleManager.java:198)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.stop(DebugUIPlug in.java:388)
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui.console 4 120 2009-03-12 18:15:15.021
!MESSAGE An exception occurred during console notification
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Previous Topic:How do I convert a tree selection to a ITreeTranslationUnit
Next Topic:can't find g++ include path.
Current Time: Sat Nov 08 04:26:47 EST 2025
Powered by FUDForum. Page generated in 0.04023 seconds
