Home » Language IDEs » Java Development Tools (JDT) » Classpath Container not working
Classpath Container not working [message #231546] Thu, 15 June 2006 13:51 Go to next message
I've written a plugin to contribute a new classpathContainerInitializer to
the JDT. It works perfectly well when I launch a test workspace from the
PDE.
However, when I package the plugin in a jar file it does not work (for the
same project tested during the PDE test). I can see via the Help menu and
the plug-in views that the plugin is installed and active, but as far as I
can tell it never gets called.
I know the plugin is packaged correctly because I can add a simple UI
element (the Hello world menu) and it works fine.
Anyone have any ideas what I might be doing wrong? There are no errors in
the log.
I'm using 3.2.
-Mike
Re: Classpath Container not working [message #231554 is a reply to message #231546] Thu, 15 June 2006 13:53 Go to previous message
FYI:
Yes, I am launching eclipse with the -clean argument to make sure it's
picking up the correct jar after an update.
-Mike
Previous Topic:Re: my own refactoring
Next Topic:Search for inheritance chain
Current Time: Fri Jul 25 23:39:52 EDT 2025
Powered by FUDForum. Page generated in 0.04401 seconds
