Home » Eclipse Projects » GEF » Painting figures with SWTGraphics does not work any longer.
Painting figures with SWTGraphics does not work any longer. [message #231243] Thu, 01 March 2007 09:41 Go to next message
Hi all,
in my code I used to have a loop that painted a set of figures to an
org.eclipse.swt.graphics.Image:
Image image = new Image(Display.getDefault(), imageSize.width, imageSize.height);
for (IFigure figure: previewedFigures)
GC gc = new GC(image);
gc.setAntialias(isAntialiasing() ? SWT.ON : SWT.OFF);
gc.setTextAntialias(isAntialiasing() ? SWT.ON : SWT.OFF);
Graphics graphics = new SWTGraphics(gc);
graphics.translate(selectionBounds.getLocation().negate());
figure.paint(graphics);
graphics.dispose();
gc.dispose ();
It worked fine with Eclipse 3.1. With 3.2 it does not work any longer.
I get a white image and no figures are drawn. Actually they seem to be
drawn because to check I overrode a couple of draw methods and they are
really called, even with sane parameters. However, the image is plain
white. Strangely, when I add a draw in the loop myself, like e.g.
graphics.setForegroundColor(ColorConstants.green);
graphics.drawRectangle(3, 4, imageSize.width-6, imageSize.height-8);
the rectangle is there. Is there anything I am doing wrong here (which
just _happened_ to work in earlier versions)? Should that actually be
posted on the SWT list?
Thanks and regards, Thomas.
Re: Painting figures with SWTGraphics does not work any longer. [message #231289 is a reply to message #231243] Fri, 02 March 2007 10:25 Go to previous messageGo to next message
Originally posted by: none.unknown.com
I bet all your figures are sized 0,0. They used to have a default size of
60x40 or something, and that default size was changed to be 0,0 afterwards.
"Thomas Maier" <Thomas.Maier@uni-kassel.de> wrote in message
news:45E6E602.1070601@uni-kassel.de...
> Hi all,
> imageSize.height);
> graphics.dispose();
> gc.dispose ();
Re: Painting figures with SWTGraphics does not work any longer. [message #231367 is a reply to message #231289] Wed, 07 March 2007 05:57 Go to previous messageGo to next message
Hi Pratik,
thanks for the followup. I just added a System.out.println to print the
bounds and the size of each figure. Looks fine. Another thing I have
observed is that connections are drawn, while the nodes are not. And it
is only a problem with the SWTGraphics/GC. As soon as I use another
graphics object (PDF, SVG, EPS), it works (everything is drawn). Any
other ideas?
Thanks, Thomas.
>> Hi all,
>> imageSize.height);
>> graphics.dispose();
>> gc.dispose ();
Re: Painting figures with SWTGraphics does not work any longer. [message #231552 is a reply to message #231367] Sat, 10 March 2007 08:47 Go to previous messageGo to next message
Originally posted by: none.ibm.com
I seem to remember a bug in SWT where the paint event contained an empty
rectangle instead of the damaged region. Have you tried using different
builds or platforms?
news:45EE9A8D.9060605@uni-kassel.de...
> Hi Pratik,
> other ideas?
> Thanks, Thomas.
Re: Painting figures with SWTGraphics does not work any longer. [message #231598 is a reply to message #231552] Mon, 12 March 2007 16:29 Go to previous message
Hi Randy, good point, thanks. We tried it on MacOS and it works fine there.
Unfortunately, the bug occurs on my main development platform: Linux
(Ubuntu Edgy), Eclipse Version: 3.2.2 Build id: M20070212-1330. Do you
remember a workaround for the bug?
Fortunately, I ordered a MacBook Pro last week ;).
>> Hi Pratik,
>> other ideas?
>> Thanks, Thomas.
Previous Topic:REQ_MOVE and overlapping Layers problem
Next Topic:JUnit testing of GEF application
Current Time: Sat Jul 19 03:00:53 EDT 2025
Powered by FUDForum. Page generated in 0.04733 seconds
