Home » Language IDEs » Java Development Tools (JDT) » JDT Java editor drawing box around text area
JDT Java editor drawing box around text area [message #230841] Wed, 07 June 2006 10:49 Go to next message
--------------010002090601030908060804
Content-Type: text/plain; charset=us-ascii; format=flowed
How does the JDT draw the box (the blue box in the attached image)
around the text area? I would greatly appreciate it if someone points
me the JDT code that does this.
please see attached image.
Content-Type: image/gif;
name="jdtbox.gif"
Content-Disposition: inline;
filename="jdtbox.gif"
R0lGODlhVgGNAPcCAP///38AVQAAAOjy/kZkpf9L/xcNAQAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAABLW4AAAAMgAAHyRBRYE8NesAFEAEnyR BRUTeAVtAAB8
kQAAAJEEPQAAfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIoAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAM4AAHyRMwDefdT8AAAAEgAVABLYeO4YAMB8kHyRQP///0C7 /458kQAB1gAA
RdbwAIAAEsAQABLYeO4YAHB8kHyRBf///wAA/z0AAHyRBBLYJAt1AAB8gQAA APQwmP//ApgC
8QL0MAAAGAAAAAwAAAAS2AAAQAAAAPAAAAAS1wAAAAAAAAAAAAAAAAAADAAC AAEAAHyQAf38
AAAkfwAAAAAAAAAAAgAsAPgCGgAWBAAAAAT4AAUAFgAAAIDi3+XlfEh8kHyB DgACbNhkAGwA
EgAS2AAACAAOAIQAAALx7AAAAAJsAJ4AAABAnvQwmAAAAgDAAAAAAAAAAAAC AAAAAAAAAAAA
AAAAAAAAAAAAAJDl5fjMfGx8gQAAAhLYmCH5BAgyAAIALAAAAABWAY0AAAj+ AAEIHEiwoMGD
CBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIEOKHEmypMmTKFOqXMmypcuX MGPKnEmzps2b
OHPqdBgggMGePR0KKChgqFCSQH0OTEp0p9OnUJcqfWiUYFWGV0UGLbh1YNao YMOeZCowKdCG
XwGkRXi1qNu1AMwqPXtW6s+pXsXq3YsUb1y/C9PCNThY4dbDc/F2tduUr+PH Ghf/hSiYqtW3
gxGXTUxQ8uTGkEOLhijZs8LKIzV/XuzZc+HRsEeXBnz64GuMqlVvvks4tu/f f5nKpd37slu0
E+sqH85cbl7g0KNPvB2VuvTr0q0/1Y69u/fv4MP+ix9Pvrz58+jTq1/Pvr37 9/Djy59Pv350
7vbzr8evv/95/v4FKB6AAhaIHYEGJnifggymh2CDEEL2YIQU7jVhhRhmqOGG HHbo4Ycghiji
iCSWaOKJKKao4ooszmQabxddWFFRMWLUVotgvQiWjBbdiGNLZAVXl5DEGUej QMcZWdVbgWGG
HFZMInmkV1GqlaRVxRHF44+GKcbZblhhKeZzS46p0Ws+PkemmmqBxiaVXPbV 2ZefQTnlm0gq
ORhmt/V5JZ5tUlllnm7GiRJrdOqYUFZfMSoSd44WumeWhh7qJZir1fZmpIFu SamUZnJKaKea
mglnpR45t9xUQ7I1qJP+Ul4Ja0azWqnkrbFOWWugptqK6q9PjtorsMS66Wmx yCar7LLMNuvs
s9BGK+201FarU5AbZaUoY0dxNKhExy56EoHh+rZtjxSdG1KaJJVbEmqArjec VF3RVaSZQTq3
WauuormrsZehdWeTduo68KzfDtyvbQwX6t5smNIVLLersXrvpzWyqbC4E3Ms LK+ElqmxdfD2
6q5sfummLp6IRnyxw4T9G+qMUFL158fC8kmzoEzyKXJ8ENe5Ms4tC/3ysDvj bFnHHTcK83QN
O3yyaEHXezTLlxpdFtPojry0wIGZyqlRcG3MVtQmA62vkPSufJWqiFn8sswU vUod3WjH/Cf+
wlXyLVTCeYM84tQpEb6S4UqHiDiwi1vr+OOQRy755JRXbvnlmGeuX+Oa58d5 5/Z9Djp9oo8e
X+mmn546i6iv3l7rrrMHe+y012777biDN8DuvPfu++/ABy/88MQXb/zxyCev /PLMN++88QRE
L/301Fdv/fXYZ4998gUY8Pz34Icv/vjkl2+++AScf376yHev/vvwxy///PQj z379zt9vvPv4
9+///wAMYO/0J8DiEZB4/CugAhfIwAZCz4HDO+DwEgjBCvKuKADEYPEwk0G3 mE8Au2OfBukH
Qt+V8IID3N0JJ+g9C7pQhQFcIfFkiL8T0hB8JbzfDZ+3QxjOMIX+A+hh7yj4 Qhxi0INBRGIS
k2jDI85QiUxcogZH+JbfyZCDvbviEUG4xSwqcYtNpGLwqnhBMjKRhifUofE8 OMUvmhGFXkQj
79RoxRMSsYjfs6EP9zhCPgpxhSVsIhyDuEdCZvGQgyykIFUYSEWW0YSIvCEg HWnIQlaSjsNb
5CQtiUhIenIAmPQi7+6IR+dx0ZCbrGQi/4jFVOqRkVBU5Rmt2MlKvtKVdSTj DrE4S1jGMo2J
HGMkedlDSdIyhMEEHilLybxTNnKQckxmLVcJTUpK05KptCUccfnJaVozkpmc 4zVr+cxjAs+Y
nwxl8JbJTOU505rRXOIjpblIVJazj6r+zGY+56nNfXJyl9uc5yb/KM5/urKc n7ziOc2pTkaO
soXtzGM+3QhFNtbTl2GcqDwtitGOlpGi9uRiG6n4Rl5G8aNSLOkbL3lGQGrx lB6FpTljylKD
DhGiEc2pMAUoxFLm0JQ83CAQ0flQnRo1l/5bqVF/mjylulOoBe3p7th51Kpa tYAStGBW14nT
q3r1q//TnljHSlaycq+rxMudWtfK1ra69a1wfc/s4nqdudIVOna962/yqlff 8LWvovkrYEMj
2ME+prCGtVBiF8vYxjr2sZCNrGQnS9nKWrZEiL3sTTKrWZpwtrMy+SxoYyLa 0baktKZlCWpT
q5LVsnZcr40SrWxnS9va2va2uM2tbneboYAAACH+ADs=
--------------010002090601030908060804--
Re: JDT Java editor drawing box around text area [message #230854 is a reply to message #230841] Wed, 07 June 2006 10:57 Go to previous messageGo to next message
Hi AL,
the Java editor uses a linked mode setup to display the boxes, to manage
navigation between them, and to link multiple occurrences of the same
variable.
@see org.eclipse.jface.text.link.LinkedModeUI
@see org.eclipse.jface.text.link.LinkedModeModel
Alternatively, if you just want to draw boxes, but not have any special
editing behavior, you can do it using annotations.
@see org.eclipse.jface.text.source.Annotation
@see org.eclipse.ui.texteditor.MarkerAnnotationPreferences
-tom
Re: JDT Java editor drawing box around text area [message #230883 is a reply to message #230854] Wed, 07 June 2006 14:25 Go to previous messageGo to next message
> Hi AL,
> variable.
> -tom
Thanks very much, Tom, for the tips! I would prefer to use the jface
text framework because my editor is already using ISourceViewer, etc.
Re: JDT Java editor drawing box around text area [message #230890 is a reply to message #230854] Wed, 07 June 2006 14:48 Go to previous messageGo to next message
> Hi AL,
> variable.
> -tom
Sorry...One more question...I look at the documentation, and it says to
use SourceViewerDecorationSupport class which has all kinds of
strategies, including drawing the box around the text, the squiggly
line, etc.
my question is: How and/or under what conditions I kick start these
strategies? That is, what do I have to do to cause the drawing to start
and to reset the drawing?
Re: JDT Java editor drawing box around text area [message #230940 is a reply to message #230890] Thu, 08 June 2006 03:17 Go to previous messageGo to next message
AL wrote:
>>> points me the JDT code that does this.
>> Hi AL,
>> manage navigation between them, and to link multiple occurrences of
>> the same variable.
>> special editing behavior, you can do it using annotations.
>> -tom
> to use SourceViewerDecorationSupport class which has all kinds of
> line, etc.
> start and to reset the drawing?
This is automatically done if you add or remove your annotations.
Dani
Re: JDT Java editor drawing box around text area [message #231032 is a reply to message #230940] Thu, 08 June 2006 15:05 Go to previous messageGo to next message
Daniel Megert wrote:
>>> Hi AL,
>>> the same variable.
>>> -tom
>> line, etc.
> Dani
So, got it...Just like markers. Thanks!
Re: JDT Java editor drawing box around text area [message #231074 is a reply to message #230940] Fri, 09 June 2006 02:30 Go to previous messageGo to next message
>>> Hi AL,
>>> the same variable.
>>> -tom
>> line, etc.
> Dani
Oh, boy...I am still quite lost. I've been reading documentation and
that I can create a SourceViewerDecorationSupport and associate it to my
source viewer.
All I want to do is to draw a red box around a text range. I see that
SourceViewerDecorationSupport has the box strategy to draw the box
(1) How do I create the box annotation? I look at the Annotation class
and I can't find the annotation type id (a string) that represents the
box drawing strategy. Do I have to define extension points?
(2) where to I add and remove the annotation?
Thanks.
Re: JDT Java editor drawing box around text area [message #231091 is a reply to message #231074] Fri, 09 June 2006 04:00 Go to previous messageGo to next message
>>>> Hi AL,
>>>> the same variable.
>>>> -tom
>>> line, etc.
>> Dani
> my source viewer.
> class and I can't find the annotation type id (a string) that
> represents the box drawing strategy. Do I have to define extension
> points?
Yep, see org.eclipse.ui.editors.annotationTypes and
org.eclipse.ui.editors.markerAnnotationSpecification extension points.
There you can specify BOX text style.
On the annotation model (which you get from your document provider).
Dani
> Thanks.
Re: JDT Java editor drawing box around text area [message #231123 is a reply to message #231091] Fri, 09 June 2006 13:43 Go to previous messageGo to next message
>>>>> Hi AL,
>>>>> the same variable.
>>>>> -tom
>>>> line, etc.
>>> Dani
>> my source viewer.
>> points?
> Dani
>> Thanks.
thanks again for the response...My scenerio is that I don't use the
documentation provider at all. I "embed" my source viewer (editable) in
a layout, just like how the JDT shows when you do
"Preferences->Java-Editor->Syntax Coloring".
Can I simply create the IAnnotationModel (that is, AnnotationModel
class) and connect it to my IDocument? But the question is: What is
the relationship with the annotation model and the source view and/or
the source viewer configuration? When I do
IAnnotationModel.addAnnotation(...), how would the source viewer to told
to do the box?
Thanks so much for your help so far.
Re: JDT Java editor drawing box around text area [message #231130 is a reply to message #231123] Fri, 09 June 2006 14:22 Go to previous messageGo to next message
>>>> AL wrote:
>>>>> Tom Eicher wrote:
>>>>>>> image) around the text area? I would greatly appreciate it if
>>>>>>> someone points me the JDT code that does this.
>>>>>> Hi AL,
>>>>>> of the same variable.
>>>>>> -tom
>>>>> says to use SourceViewerDecorationSupport class which has all kinds
>>>>> of strategies, including drawing the box around the text, the
>>>>> squiggly line, etc.
>>>> Dani
>>> my source viewer.
>>> that SourceViewerDecorationSupport has the box strategy to draw the
>>> points?
>> Dani
>>> Thanks.
> to do the box?
I see ISourceViewer#setDocument(IDocument, IAnnotationModel, int, int).
I can set my own annotation model, even though the annotation model
in the org.eclipse.jface.text.source.SourceViewer, which my source
viewer derives off, says that it is for the ruler annotation. Sounds
like the right usage?
thanks.
Re: JDT Java editor drawing box around text area [message #231246 is a reply to message #231130] Mon, 12 June 2006 09:58 Go to previous message
AL wrote:
>>>>>>> Hi AL,
>>>>>>> to manage navigation between them, and to link multiple
>>>>>>> occurrences of the same variable.
>>>>>>> -tom
>>>>>> kinds of strategies, including drawing the box around the text,
>>>>>> the squiggly line, etc.
>>>>>> these strategies? That is, what do I have to do to cause the
>>>>>> drawing to start and to reset the drawing?
>>>>> Dani
>>>> and that I can create a SourceViewerDecorationSupport and associate
>>>> it to my source viewer.
>>>> points?
>>> points. There you can specify BOX text style.
>>> Dani
>>>> Thanks.
>> in a layout, just like how the JDT shows when you do
>> told to do the box?
> int). I can set my own annotation model, even though the annotation
> model in the org.eclipse.jface.text.source.SourceViewer, which my
> source viewer derives off, says that it is for the ruler annotation.
> Sounds like the right usage?
And you must setup the source viewer decoration support. See
AbstractDecoratedTextEditor for a template how to do this.
Dani
> thanks.
Previous Topic:AST walking of large sources
Next Topic:Eclipse Editor Environment
Current Time: Mon Nov 10 04:38:20 EST 2025
Powered by FUDForum. Page generated in 0.08721 seconds
