Home » Language IDEs » ServerTools (WTP) » JSPJavaHyperlinkDetector contains invalid attributes??
JSPJavaHyperlinkDetector contains invalid attributes?? [message #230479] Fri, 17 April 2009 02:47 Go to next message
Hi!
I use a eclipse 3.2.4
and i found the following error in the log file:
eclipse.buildId=M20090211-1700
java.version=1.6.0_10-rc2
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -Xms256M -Xmx1500M -XX:PermSize=128M
-XX:MaxPermSize=256M
Command-line arguments: -os linux -ws gtk -arch x86 -Xms256M -Xmx1500M
-XX:PermSize=128M -XX:MaxPermSize=256M
Error
Fri Apr 17 08:30:37 CEST 2009
The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
I do not really know what that means, looks like eclipse behaves quite
normal.
But anyway, it is for sure not as it should be so: Has someone an idea how
- the invalid values got in there? ( i upgraded so maybe there was
something thrown out???)
- how to get rid of them? (a hint where i find them at all could be
helpful ;-)
Best Regards
Søren
Re: JSPJavaHyperlinkDetector contains invalid attributes?? [message #230487 is a reply to message #230479] Fri, 17 April 2009 20:59 Go to previous messageGo to next message
It'll be corrected in the forthcoming WTP 3.0.5 and 3.1 releases.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=263021
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: JSPJavaHyperlinkDetector contains invalid attributes?? [message #230526 is a reply to message #230487] Mon, 20 April 2009 04:19 Go to previous message
Cool, thx for the information! Hope that is not something dangerous, then
i can wait until the next upgrade!
Søren
Previous Topic:Publishing static website to HTTP server fails
Next Topic:How to do custom XML partitioning?
Current Time: Sat Jul 26 15:23:28 EDT 2025
Powered by FUDForum. Page generated in 0.03156 seconds
