Home » Language IDEs » ServerTools (WTP) » Where to construct IStructuredDocument
Where to construct IStructuredDocument [message #230190] |
Wed, 08 April 2009 17:04  |
Dear, All,
I encountered an "unknown IStructuredDocument" error with an extended WTP
XML editor. The editor extends StructuredTextEditor, and uses
StructuredTextViewerConfigurationXML.
It works fine with XML file. But our data input is a small portion of a
large file, which feeds XML fragment to the editor as a java object. I
implemented IStorageEditorInput on the object. The editor opens up with
XML fragment, having syntax highlighting. But, when trying to run Document
Format action, I encountered the "unknown IStructuredDocument" error.
My question is: Where to construct IStructuredDocument?
I tried to do it in a FileDocumentProvider, the editor just throws
numerous errors if I set document provider.
Best Regards,
Frank
For your reference, below is the log:
!ENTRY org.eclipse.ui 4 4 2009-04-08 16:54:11.999
!MESSAGE "Format" did not complete normally. Please see the log for more
information.
!ENTRY org.eclipse.ui 4 0 2009-04-08 16:54:12.077
!MESSAGE unknown IStructuredDocument
org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment @d642fd
!STACK 0
org.eclipse.wst.sse.core.internal.util.Assert$AssertionFaile dException:
at
org.eclipse.wst.sse.core.internal.util.Assert.isNotNull(Asse rt.java:124)
at
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._ge tModelFor(ModelManagerImpl.java:541)
at
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.get ModelForEdit(ModelManagerImpl.java:1292)
at
org.eclipse.wst.xml.ui.internal.XMLFormattingStrategy.format (XMLFormattingStrategy.java:58)
at
org.eclipse.jface.text.formatter.MultiPassContentFormatter.f ormatMaster(MultiPassContentFormatter.java:193)
at
org.eclipse.wst.sse.ui.StructuredTextMultiPassContentFormatt er.formatMaster(StructuredTextMultiPassContentFormatter.java :56)
at
org.eclipse.jface.text.formatter.MultiPassContentFormatter.f ormat(MultiPassContentFormatter.java:135)
at
org.eclipse.wst.sse.ui.internal.StructuredTextViewer.doOpera tion(StructuredTextViewer.java:513)
at
Re: Where to construct IStructuredDocument [message #230214 is a reply to message #230190] |
Thu, 09 April 2009 00:24   |
Frank Du wrote:
> Dear, All,
> WTP XML editor. The editor extends StructuredTextEditor, and uses
> Document Format action, I encountered the "unknown IStructuredDocument"
> error.
> Best Regards,
> Frank
> more information.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at .....
You shouldn't need to use the FileDocumentProvider since the
TextFileDocumentProvider will already support files in the
workspace. We usually discourage subclassing StructuredTextEditor
since that's what the viewer configurations are for.
The error message is indicating that the document in the editor
isn't shared as part of an IStructuredModel in the SSE
IModelManager. The formatting functionality requires access to the
model, and in this case there's no way to pass that object through
the MultiPassContentFormatter API. The XMLFormattingStrategy has to
look it up somehow, hence the IModelManager's involvement and the
need to use a shared model. Most of the time the editor's being
opened on IFiles in the workspace or java.io.Files in the
filesystem, which are handled by the TextFileDocumentProvider, or
with an implementor of IStorageEditorInput which we then handle with
our own StorageModelProvider. The
org.eclipse.ui.editors.documentProviders extension point can be used
to map your own input type to a document provider. My own
experience is that cooking up your own document provider is usually
more trouble than it's worth (we're up to
IDocumentProviderExtension5 now), and that it's simpler instead to
create an editor input that can be used by an existing provider.
If you need to show an arbitrary bit of text in the
StructuredTextViewer_, and need it to be shared, create the model
using the IModelManager.getModelForEdit(String, InputStream,
URIResolver) method and set that model's IStructuredDocument into
the viewer. The string name you give it will be important in
helping to find the right content type and model handlers to build
the XML model. As with all shared models, be sure to release it
when you're done using it.
You're not the first one to run into this snag, as it's hit our own
committers from time to time:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270888 . Good luck.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Where to construct IStructuredDocument [message #230305 is a reply to message #230214] |
Mon, 13 April 2009 17:27   |
Hi Natin,
Thank you so much for the detailed reply. I consulted you at eclipsecon
about it, and have created IStorageEditorInput class now. Here is our
scenario:
1. We have a config file which contains several kinds of configuration text
2. A multi-page editor is created.
3. From the main editor page, users can open different kinds of configs in
different editors. New editors go to new editor tab pages.
4. The Properties "file" editor and text editor work fine now. I use
IDocumentProvider to sync the changes between memory objects and textual
representation.
5. For the xml editor, we can retrieve text from memory config object, and
display the xml fragment properly. But how could I save changes back to
memory objects.
I have gone through the source code, and don't have enough clues. Natin,
could you please tell me which method to override or replace, to save the
changes?
Best Regards,
Frank
Re: Where to construct IStructuredDocument [message #230364 is a reply to message #230305] |
Tue, 14 April 2009 23:40   |
> scenario:
> in different editors. New editors go to new editor tab pages.
> representation.
> and display the xml fragment properly. But how could I save changes back
> to memory objects.
> the changes?
Well, that's a hard one--offering the ability to save to something
that's not a file has not been a big use case for us. In this
situation, I think there's no choice but to subclass and override
org.eclipse.wst.sse.ui.StructuredTextEditor.setDocumentProvi der(IEditorInput)
for your source page so that it uses your own document provider for
your editor input. Although it's discouraged in the JavaDoc, the
StructuredTextEditor class isn't marked final.
Nitin Dahyabhai
IBM Rational
Re: Where to construct IStructuredDocument [message #230428 is a reply to message #230364] |
Wed, 15 April 2009 16:38   |
Originally posted by: dcarver.starstandard.org
As XML Databases become more popular, this type of non-file saving will
become more prevelant. Consider a situation where an XQuery is run to
retrieve the information, and a XQuery Update is executed to update the
information. The XML Editor may be used to view the results or you may
want to make changes directly to the xml and restore it back in the
database. In this particular case, there is no physical file per say,
as the update and retrievel could be done through API or through RESTful
web service interfaces.
Dave
>> eclipsecon about it, and have created IStorageEditorInput class now.
>> Here is our scenario:
>> text
>> configs in different editors. New editors go to new editor tab pages.
>> textual representation.
>> back to memory objects.
>> Natin, could you please tell me which method to override or replace,
>> to save the changes?
> for your source page so that it uses your own document provider for your
Re: Where to construct IStructuredDocument [message #230796 is a reply to message #230428] |
Mon, 27 April 2009 18:34   |
Hi David,
I agree with you. Aside from requirements from technical evolution, there
are also requirements from target users. XML is great for technicians, but
may be too verbose or cumbersome for normal software users, especially
when it grows very large. So, you wish to display a small portion of large
xml. You wish to break it into pieces and present pieces in some form UI.
That's the reason why we are doing it this way. Hope it helps to explain
the use scenarios and make WTP editors more generic for such situations.
Thank you so much, David and Nitin! I will try Nitin's suggestion soon,
and keep this thread posted.
Have a good one day!
Best Regards,
Frank Du
> Dave
Re: Where to construct IStructuredDocument [message #230867 is a reply to message #230364] |
Tue, 28 April 2009 17:01  |
Dear Nitin & All,
I finally put up all the suggestions from several my newsgroup posts.
Woo-hoo! Finally got working code now! The steps I went through are:
1. Implement IStorage.
2. Implement IStorageEditorInput.
With the steps so far, the embedded xml editor can read the document
contents from in-memory objects.
3. Copy and modify source code of StorageModelProvider, to insert my code
to doSaveDocument(...) method. The code will update in-memory objects,
when the input is our IStorageEditorInput.
With the step 3, the embedded xml editor can save changes back to
in-memory objects.
4. In the editor class (subclass StructuredTextEditor), override the
method setDocumentProvider(IEditorInput input). When input is our storage
editor input, set it to use the modified StorageModelProvider.
With the steps above, everything works now. It just, of course, looks like
ugly code. IMH, it may be beautiful if the StructuredModelManager yields
StructuredModel and StructuredDocument not based on IFile but on
IEditorInput.
Wish the above information helps for those who run into similar issues.
Thanks so much to all of you, especially to Nitin!
Best Regards,
Frank Du
>> scenario:
>> representation.
>> to memory objects.
>> the changes?
Current Time: Fri Jul 25 19:49:58 EDT 2025
Powered by FUDForum. Page generated in 0.06248 seconds
