Home » Language IDEs » ServerTools (WTP) » XML editor autoformat
XML editor autoformat [message #230154] Wed, 08 April 2009 04:47 Go to next message
Dear all,
I'm using eclipse's (version 3.4.2) xml editor to edit a configuration xml
for my application. The configuration file is quite complex, so autoformat
comes in handy.
Some elements of my xml file contain script code. I want the autoformatter
to leave those elements alone and NOT format them like regular text.
Is there a way to achieve this? Any hint welcome.
(I know that i can set the XML editor preferences under
window->preferences, and that i can check `Preserve Whitespace in Tags
with PCDATA content'. But that doesn't help me, probably because my xml is
schema-based, and PCDATA is a DTD concept.)
Thanks, Mike
Re: XML editor autoformat [message #230162 is a reply to message #230154] Wed, 08 April 2009 05:32 Go to previous messageGo to next message
Strange, when i uncheck the `clear all blank lines' option, the XML
formatter does respond to the `preserve whitespace in PCDATA tags'
option... Could it be that the formatter is still slightly buggy?
Re: XML editor autoformat [message #230168 is a reply to message #230154] Wed, 08 April 2009 10:50 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Have you tried adding the xml:space="preserve" attribute to those
elements where you want to keep the formatting that you have specified?
Dave
Mike W wrote:
> Dear all,
> xml for my application. The configuration file is quite complex, so
> autoformat comes in handy.
> autoformatter to leave those elements alone and NOT format them like
> regular text.
> is schema-based, and PCDATA is a DTD concept.)
> Thanks, Mike
Re: XML editor autoformat [message #230174 is a reply to message #230162] Wed, 08 April 2009 10:52 Go to previous messageGo to next message
Yes, there are several known bugs in the formatter. If you do a search
on "format" in the summary of the wst.xml component you'll find about 24
of them that have been opened.
We are aware of them, and hope to address them in the near future.
Dave
Re: XML editor autoformat [message #230182 is a reply to message #230168] Wed, 08 April 2009 15:42 Go to previous messageGo to next message
Hello Dave,
Thanks for your reply! The autoformatter now works good enough, when not
discarding empty lines... If i run into trouble again i'll try the
xml:space="preserve" attribute.
Thanks! Mike
Re: XML editor autoformat [message #230198 is a reply to message #230168] Wed, 08 April 2009 17:08 Go to previous message
This worked, although i had to restart eclipse after changing the xsd.
The xsd for the script element now looks as follows:
<xs:element
name="scriptBlock"
minOccurs="0">
<xs:complexType>
<xs:simpleContent>
<xs:extension
base="xs:string">
<xs:attribute
ref="xml:space"
fixed="preserve" />
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
In the top of the xsd file, you must also import the xml namespace
and declare the namespace in the schema element
<xs:schema
targetNamespace="http://www.yourcompany.com"
elementFormDefault="qualified"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xml="http://www.w3.org/XML/1998/namespace"
xmlns="http://www.yourcompany.com">
<xs:import
namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/xml.xsd" />
Hope this is useful for some.
Bye, Mike
Previous Topic:Start Server with Error Message
Next Topic:WTP project configuration is failing
Current Time: Sat Jul 19 01:15:31 EDT 2025
Powered by FUDForum. Page generated in 0.05029 seconds
