Home » Modeling » GMF (Graphical Modeling Framework) » How to avoid scrollbars
How to avoid scrollbars [message #229981] Wed, 13 May 2009 07:04 Go to next message
Hello again,
I need a fixed editor panel w/o possibility to scroll or resize.
In which class i have to do mofications ?
Greets
Patrick
Re: How to avoid scrollbars [message #230148 is a reply to message #229981] Wed, 13 May 2009 11:06 Go to previous message
I found a way to remove the srollbar of the EditorPart in a refreshBounds
method of a node edit part:
Object xx = getParent();
if (xx instanceof SystemEditPart)
SystemEditPart pa = (SystemEditPart) xx;
EditPart ep = pa.getParent();
FigureCanvas c = (FigureCanvas) ep.getRoot().getViewer().getControl();
c.setScrollBarVisibility(org.eclipse.draw2d.FigureCanvas.NEV ER);
But probaly i should insert the code at a better place ;)
Patrick Schmitt wrote:
> Hello again,
> Greets
> Patrick
Previous Topic:is it possible to make label invisible?
Next Topic:Customizing diagram menus & perspectives
Current Time: Mon Sep 15 19:14:51 EDT 2025
Powered by FUDForum. Page generated in 0.03796 seconds
