Home » Modeling » Epsilon » EuGENia link attributes
EuGENia link attributes [message #21991] Fri, 10 July 2009 20:05 Go to next message
Hi there,
I'm using EuGENia to help with a diagram editor of mine, which creates
components including GMF links. I can specify labels for these links using
gmf annotations such as, @gmf.link(... label="name"). I'm now wondering
whether there is an easy way to go abouts adding labels to the ends of the
link (e.g., as you might have when defining association multiplicities in
a standard UML editor)?
All the best,
Edd
Re: EuGENia link attributes [message #22080 is a reply to message #21991] Sat, 11 July 2009 17:13 Go to previous messageGo to next message
Hi Edd,
This is not supported by EuGENia at the moment but I'll have a look to
see how it could be. Does your metamodel like this?
class Class {
class AssociationEnd {
attr String name;
ref Class type;
class Association {
val AssociationEnd[2] ends;
or like this?
class Class {
class Association {
val Class[2] ends;
Dimitris
Edward Turner wrote:
> Hi there,
> using gmf annotations such as, @gmf.link(... label="name"). I'm now
> wondering whether there is an easy way to go abouts adding labels to the
> ends of the link (e.g., as you might have when defining association
> multiplicities in a standard UML editor)?
> All the best,
> Edd
Re: EuGENia link attributes [message #22866 is a reply to message #22080] Tue, 14 July 2009 08:39 Go to previous messageGo to next message
Dimitris Kolovos wrote:
It is more like the latter, but with 'ref's instead of 'val's -- so more
than one association can comprise the same class:
class Association {
ref Class xEnd;
ref Class yEnd;
> Cheers,
> Dimitris
Ta,
Edd
Re: EuGENia link attributes [message #22998 is a reply to message #22866] Tue, 14 July 2009 12:29 Go to previous messageGo to next message
Hi Edd,
Thanks. I'll have a look at this shortly and get back to you.
Dimitris
> class Association {
> ref Class xEnd;
> ref Class yEnd;
>> Cheers,
>> Dimitris
> Ta,
> Edd
Re: EuGENia link attributes [message #23083 is a reply to message #22998] Mon, 20 July 2009 05:36 Go to previous messageGo to next message
Hi Edd,
I've put together an example that does this and it's now available under
http://www.eclipse.org/gmt/epsilon/examples/index.php?exampl e=org.eclipse.epsilon.eugenia.examples.endlabels
I've had to use the "polishing" feature of EuGENia
http://epsilonblog.wordpress.com/2009/06/15/eugenia-polishin g-your-gmf-editor/
as multiple connection labels are not currently supported by the
annotations. If you have any trouble adapting the EOL code to your
example please let me know.
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> more than one association can comprise the same class:
>> class Association {
>> ref Class xEnd;
>> ref Class yEnd;
>>> Cheers,
>>> Dimitris
>> Ta,
>> Edd
Re: EuGENia link attributes [message #23123 is a reply to message #23083] Tue, 21 July 2009 10:45 Go to previous message
Ahh, brilliant :) Thanks Dimitris -- just what was needed. And I'm sure
this will be handy to know in the long run for everyone!
Ta,
Edd
Re: EuGENia link attributes [message #570485 is a reply to message #21991] Sat, 11 July 2009 17:13 Go to previous message
Hi Edd,
class Class {
attr String name;
ref Class type;
class Association {
or like this?
class Class {
class Association {
val Class[2] ends;
Dimitris
> Hi there,
> All the best,
> Edd
Re: EuGENia link attributes [message #570815 is a reply to message #22080] Tue, 14 July 2009 08:39 Go to previous message
class Association {
ref Class xEnd;
ref Class yEnd;
> Cheers,
> Dimitris
Ta,
Edd
Re: EuGENia link attributes [message #570924 is a reply to message #22866] Tue, 14 July 2009 12:29 Go to previous message
Hi Edd,
Dimitris
> class Association {
> ref Class xEnd;
> ref Class yEnd;
>> Cheers,
>> Dimitris
> Ta,
> Edd
Re: EuGENia link attributes [message #570958 is a reply to message #22998] Mon, 20 July 2009 05:36 Go to previous message
Hi Edd,
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> class Association {
>> ref Class xEnd;
>> ref Class yEnd;
>>> Cheers,
>>> Dimitris
>> Ta,
>> Edd
Re: EuGENia link attributes [message #570970 is a reply to message #23083] Tue, 21 July 2009 10:45 Go to previous message
Ta,
Edd
Previous Topic:how to give an Ecore DataType to an attribute
Next Topic:ETL rule execution
Current Time: Tue Sep 16 16:11:24 EDT 2025
Powered by FUDForum. Page generated in 0.04143 seconds
