Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229721 is a reply to message #229713] |
Thu, 26 March 2009 14:11   |
If the server is already started, will "Run on server" make the browser
appear?
Larry
Whatty wrote:
> The browser does not appear
> I am changing the name in the settings, I guess it was silly to use an
> embedded space way back when I first created the project, and I will how
> that works.
> "Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
> news:gqg6ij$n67$1@build.eclipse.org...
>> The setting that controls the context path is the "Context Root" property
>> on the Web Project Settings page of the project's Properties dialog.
>> However, "Web module name" likely refers to the "deploy-name" attribute
>> found in the ".settings/org.eclipse.wst.common.component" file of the
>> project. Note that the "deploy-name" value needs to stay in sync with the
>> project name, or there will be bigger problems with the project.
>> Does "does not launch my initial web page" mean the browser doesn't appear
>> or the browser appears but unexpected output occurs?
>> Cheers,
>> Larry
>> Whatty wrote:
>>> I believe part of the problem is that when I run the web project on the
>>> server that the project under the server view has an embedded space in
>>> the Web module name (example "project<sp>") and it complains about not
>>> being able to find the correct folder, which is related to the context
>>> entry in the server.xml in the server local-config
>>> <Context docBase="Project 1" path="/Project1" reloadable="true"
>>> source="org.eclipse.jst.j2ee.sever:Project 1"/>
>>> See the inconsistency above from the path compared to the docBase /
>>> source.
>>> Where is this value coming from (I have searched and can't seem to track
>>> it down)?
>>> I have also tried to manually modify this value in the sever.xml in the
>>> Tomcat localhost-config and seems to be reloaded somewhere else and may
>>> changes get overwritten.
>>> Thanks in advance.
>>> Whatty
>>> "Whatty" <steven.whatmore@lynxdev.com> wrote in message
>>> news:gptcok$pcb$1@build.eclipse.org...
>>>> Good morning,
>>>> I just upgraded to 3.4.1 and now when I launch my web project (JSF /
>>>> AJAX / RichFaces) it sometimes does not launch my initial web page.
>>>> Is there a setting somewhere that I need to adjust for my project in
>>>> 3.4.1?
>>>> Thanks in advance.
>>>> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229792 is a reply to message #229721] |
Sun, 29 March 2009 17:14   |
I have removed the embedded space in the ".settings" property file and it
still does not launch the initial page sometimes.
However, as per your suggestion, if the server is started, and I ask for
"Run on server" again the browser does in fact appear.
This is workable for now but otherwise is a minor PITA (Pain in the A$$)
news:gqggg9$n8m$1@build.eclipse.org...
> appear?
> Cheers,
> Larry
>> that works.
>>> property on the Web Project Settings page of the project's Properties
>>> dialog. However, "Web module name" likely refers to the "deploy-name"
>>> attribute found in the ".settings/org.eclipse.wst.common.component" file
>>> of the project. Note that the "deploy-name" value needs to stay in sync
>>> with the project name, or there will be bigger problems with the
>>> project.
>>> appear or the browser appears but unexpected output occurs?
>>> Cheers,
>>> Larry
>>>> source.
>>>> track it down)?
>>>> Thanks in advance.
>>>> Whatty
>>>>> Good morning,
>>>>> 3.4.1?
>>>>> Thanks in advance.
>>>>> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229886 is a reply to message #229792] |
Tue, 31 March 2009 09:09  |
I have seen this behavior recently too, but haven't had time to
investigate. I'm not sure what has changed.
Larry
>> appear?
>> Cheers,
>> Larry
>>> that works.
>>>> project.
>>>> Cheers,
>>>> Larry
>>>>> source.
>>>>> track it down)?
>>>>> Thanks in advance.
>>>>> Whatty
>>>>>> Good morning,
>>>>>> 3.4.1?
>>>>>> Thanks in advance.
>>>>>> Whatty
FUDForum. Page generated in 0.04985 seconds
