Home » Eclipse Projects » GEF » Is there a zoom to selection action somewhere?
Is there a zoom to selection action somewhere? [message #229736] Wed, 24 January 2007 08:48 Go to next message
Platform: Intel Pentium M, Ubuntu Dapper,
Sun Java SDK 1.5.0_06,
eclipse 3.2.1
GEF 3.2.1
Two very useful actions in graphical editor, are zoom to fit/zoom all,
which shows all of a model, and "zoom selection", which lets you
select a bunch of objects, and then invoke the "zoom selection" to
center on the selection, and zoom to make the selection fill all of
the available view port.
Zoom all was easy, since it was built-in
(ZoomManager#setZoomAsText(ZoomManager.FIT_ALL) for the casual
reader).
But I haven't found anything like "zoom selection", neither by
browsing through the GEF source and examples, nor by googling.
Does anyone know of an implementation of a "zoom selection" action?
Failing that, does anyone have any ideas how to go about to implement
such an action?
Thanx!
- Steinar
Re: Is there a zoom to selection action somewhere? [message #229781 is a reply to message #229736] Wed, 24 January 2007 13:59 Go to previous messageGo to next message
>>>>> Steinar Bang <sb@dod.no>:
> implement such an action?
I started by calculating the bounding box of the selection, which
proved to be easy (see below). Then I looked at the operations of the
ZoomManager and found that there is a ZoomManager#zoomTo(Rectangle)
operation, and exclaimed "Yes!!"... and then I saw the implementation:
* Currently does nothing.
* @param rect a rectangle
public void zoomTo(Rectangle rect) { }
Oh well...! :-/
Calculating the bounding box, looks like this:
public class ZoomSelectionEditorActionDelegate implements IEditorActionDelegate {
public final static String ID = ZoomSelectionEditorActionDelegate.class.getCanonicalName();
private GraphicalEditor editor;
* @see org.eclipse.ui.IEditorActionDelegate#setActiveEditor(org.ecl ipse.jface.action.IAction, org.eclipse.ui.IEditorPart)
public void setActiveEditor(IAction action, IEditorPart targetEditor)
editor = (GraphicalEditor) targetEditor.getAdapter(GraphicalEditor.class);
* @see org.eclipse.ui.IActionDelegate#run(org.eclipse.jface.action. IAction)
public void run(IAction action)
EditPartViewer viewer = editor.getRoot().getViewer();
IStructuredSelection selection = (IStructuredSelection) viewer.getSelection();
System.out.println("Calculating bounding box:");
Rectangle boundingBox = null;
for (Object selObj : selection.toList()) {
GraphicalEditPart editPart = (GraphicalEditPart) selObj;
IFigure figure = editPart.getFigure();
Rectangle bounds = figure.getBounds();
if (boundingBox == null) {
boundingBox = new Rectangle(bounds);
} else {
boundingBox.union(bounds);
System.out.println(" Figure bounds: "+bounds);
System.out.println(" Bounding box: "+boundingBox);
* @see org.eclipse.ui.IActionDelegate#selectionChanged(org.eclipse. jface.action.IAction, org.eclipse.jface.viewers.ISelection)
public void selectionChanged(IAction action, ISelection selection)
// TODO Auto-generated method stub
Re: Is there a zoom to selection action somewhere? [message #229789 is a reply to message #229781] Wed, 24 January 2007 15:04 Go to previous messageGo to next message
> Oh well...! :-/
Turns out this wasn't too hard, with a bit of creative cut'n paste
from ZoomManager#getFitXZoomLevel(int). An IEditorActionDelegate that
implements this command is below.
But that isn't really the right home for the algorithm. Is it
possible to replace the ZoomManager, with one that uses this code in a
replaced zoomTo(Rectangle) method, I wonder...?
The IEditorActionDelegate that zooms to selection, follows:
GraphicalViewer viewer = (GraphicalViewer) editor.getAdapter(GraphicalViewer.class);
} else {
ZoomManager zoomer = (ZoomManager) editor.getAdapter(ZoomManager.class);
zoomer.zoomTo(boundingBox); // If this method hadn't been empty, this would have been enough...
// The rest of this method becomes unneccessary, once ZoomManager#zoomTo(Rectangle) is implemented
Dimension available = zoomer.getViewport().getClientArea().getSize();
Dimension desired = boundingBox.getSize().getCopy();
double zoom = zoomer.getZoom();
double scaleX = Math.min(available.width * zoom / desired.width, zoomer.getMaxZoom());
double scaleY = Math.min(available.height * zoom / desired.height, zoomer.getMaxZoom());
System.out.println(" scaleX: "+scaleX+" scaleY: "+scaleY);
double scale = Math.min(scaleX, scaleY);
zoomer.setZoom(scale);
zoomer.setViewLocation(boundingBox.getTopLeft());
Re: Is there a zoom to selection action somewhere? [message #229797 is a reply to message #229789] Wed, 24 January 2007 17:02 Go to previous message
> a replaced zoomTo(Rectangle) method, I wonder...?
Not easily... :-/
The ZoomManager is a private field in ScalableRootEditPart, with no
setter method. So it isn't easily replacable in a subclass, or from
the viewer user.
So... it _is_ possible to subclass ScalableRootEditPart, replace
#getZoomManager() method and the #register() and #unregister()
#methods, and disregard the private field (though wasteful and ugly).
But my earlier attempts at explicitly setting the root edit part
(based an GEF example or other) were unsuccessful, while leaving the
one GraphicalEditor set in place, worked...
We'll see what tomorrow brings. In the meantime, a completely
untested ZoomManagerNG (a better name escaped me), with a filled in
#zoomTo() method, and a brand new #zoomToSelection() method.
Enjoy!
- Steinar
* Replaces the empty {@link #zoomTo(org.eclipse.draw2d.geometry.Rectangle)}
* method of the base class. Also adds a
* {@link #zoomToSelection(IStructuredSelection)} method that can zoom to
* the best fit around the bounding box of the currently selected edit parts.
public class ZoomManagerNG extends ZoomManager {
* Only reimplement the non-deprecated constructor in the base class.
* @param pane
* @param viewport
public ZoomManagerNG(ScalableFigure pane, Viewport viewport)
super(pane, viewport);
// TODO Auto-generated constructor stub
* The base class implementation of this method is empty. This one isn't.
* What this method is to zoom so that the Rectangle argument fills the
* viewport.
* @see org.eclipse.gef.editparts.ZoomManager#zoomTo(org.eclipse.dra w2d.geometry.Rectangle)
Dimension available = getViewport().getClientArea().getSize();
Dimension desired = rect.getSize().getCopy();
double zoom = getZoom();
double scaleX = Math.min(available.width * zoom / desired.width, getMaxZoom());
double scaleY = Math.min(available.height * zoom / desired.height, getMaxZoom());
setZoom(scale);
setViewLocation(rect.getTopLeft());
* Find the bounding box of the figures of the edit parts in
* the selection argument, and call {@link #zoomTo(Rectangle)}
* on this bounding box.
* @param selection a selection of edit parts
public void zoomToSelection(IStructuredSelection selection)
} else {
Previous Topic:resizing
Next Topic:scrolling problem
Current Time: Tue Jul 22 23:03:04 EDT 2025
Powered by FUDForum. Page generated in 0.05032 seconds
