Home » Eclipse Projects » GEF » How to update connections to sub-figures?
How to update connections to sub-figures? [message #229710] Wed, 24 January 2007 05:45
I have an editor with a typical graph structure, nodes and edges. I can
drag nodes around, and edges follow nicely.
However, I added sub-figures (modeled also as separate edit parts) to my
nodes (symbolizing ports). Those edges attached to the ports of a node are
not updated when I move the node. When I open the editor again, the edges
are correctly connected to the port. (Though I expect there is simply
missing an notification to the edges that they should update.)
So, what do I have to do that not only connection attached to the nodes
are updated once the node moves, but also thos connection attached to the
sub-figures of the node (the ports)?
Thanks in advance!
Previous Topic:toolbar visibility
Next Topic:copy & paste in GEF
Current Time: Fri Jun 06 13:24:50 EDT 2025
Powered by FUDForum. Page generated in 0.16781 seconds
