Home » Eclipse Projects » GEF » How to meaure the string(text) width?
How to meaure the string(text) width? [message #229528] Sun, 21 January 2007 01:06 Go to next message
Originally posted by: zjg.robin.gmail.com
I want to draw string in the figure, and I must know the width the string, how to get such info? I know that GC has such method to get it, but how to get GC in figure object?
Thanks. Robin
Re: How to meaure the string(text) width? [message #229546 is a reply to message #229528] Sun, 21 January 2007 11:12 Go to previous messageGo to next message
Originally posted by: anthony.cunningham.NOduolog.comSPAM
Can you use a label figure and add it to the figure?
Re: How to meaure the string(text) width? [message #229560 is a reply to message #229546] Sun, 21 January 2007 23:51 Go to previous messageGo to next message
Thank you.
With your clue, I found the util class FigureUtilities which can do this and that.
Re: How to meaure the string(text) width? [message #229579 is a reply to message #229560] Mon, 22 January 2007 06:04 Go to previous messageGo to next message
I'll have to do this myself later and thought I'd just get the dimensions
of a label that I added the text to. Can you detial how you did it if you
get it to work.
Anthony
Re: How to meaure the string(text) width? [message #229587 is a reply to message #229579] Mon, 22 January 2007 09:28 Go to previous message
If you need to draw a string inside a node, perhaps, you all you need is
indeed create a GEF's label figure and add it to the node figure. For the
node figure install GEF's tool bar layout or stack layout manager, this
will resize the node figure to fit the entire label figure (i.e. to fit
the whole string). The closest example to this would StickyNoteFigure from
GEF logic example editor.
Hope this helps.
Alex
Previous Topic:EditPart figures in feedback layer
Next Topic:Draw2d for UML sequence diagram lifelines
Current Time: Sun Jun 08 06:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
