| GMF creates -1 coordinates [message #228911] |
Tue, 05 May 2009 11:29  |
Hello, IŽm currently working on a eclipse-plugin based on emf/gmf, which
allows the user to create gui-prototypes on the canvas. Every gui element
that is available in the plugin has coordinates, such as x-position,
y-position, width and height. The coordinates are used to automatically
create the gui prototype in java-swing, the elements are placed via
mOkButton.setBounds(x, y, width, height); This system works just fine in
about 95 percent of all cases, but there is a little problem left.
Sometimes there is a -1 in the generated code, in which one element of the
coordinate should be. For example mOkButton.setBounds(114, 98, -1, 50); If
i resize the width of the ok button, the real coordinate will be generated.
Thank you very much for your help
Greetings Stefan
| Re: GMF creates -1 coordinates [message #229504 is a reply to message #228911] |
Tue, 12 May 2009 07:11  |
Hello Stefan,
AFAICan see from FreeFormLayoutEx (layout manager used for the diagram figure)
- preferred size width/height of the child figure will be used in case of
"-1" specified as width/length:
if (widthHint == -1 || heightHint == -1) {
Dimension _preferredSize = f.getPreferredSize(widthHint, heightHint);
bounds = bounds.getCopy();
if (widthHint == -1)
bounds.width = _preferredSize.width;
if (heightHint == -1)
bounds.height = _preferredSize.height;
so, if you need to use non-default width/height values you have to always
set size on creating diagram elements.
Alex Shatalin
FUDForum. Page generated in 0.04594 seconds
