Home » Language IDEs » ServerTools (WTP) » Upgrade to 3.4.1 - Run on server no longer launches initial page
Upgrade to 3.4.1 - Run on server no longer launches initial page [message #229227] Thu, 19 March 2009 08:11 Go to next message
Good morning,
I just upgraded to 3.4.1 and now when I launch my web project (JSF / AJAX /
RichFaces) it sometimes does not launch my initial web page.
Is there a setting somewhere that I need to adjust for my project in 3.4.1?
Thanks in advance.
Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229447 is a reply to message #229227] Tue, 24 March 2009 10:55 Go to previous messageGo to next message
I believe part of the problem is that when I run the web project on the
server that the project under the server view has an embedded space in the
Web module name (example "project<sp>") and it complains about not being
able to find the correct folder, which is related to the context entry in
the server.xml in the server local-config
<Context docBase="Project 1" path="/Project1" reloadable="true"
source="org.eclipse.jst.j2ee.sever:Project 1"/>
See the inconsistency above from the path compared to the docBase / source.
Where is this value coming from (I have searched and can't seem to track it
down)?
I have also tried to manually modify this value in the sever.xml in the
Tomcat localhost-config and seems to be reloaded somewhere else and may
changes get overwritten.
Thanks in advance.
Whatty
"Whatty" <steven.whatmore@lynxdev.com> wrote in message
news:gptcok$pcb$1@build.eclipse.org...
> Good morning,
> / RichFaces) it sometimes does not launch my initial web page.
> 3.4.1?
> Thanks in advance.
> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229697 is a reply to message #229447] Thu, 26 March 2009 11:21 Go to previous messageGo to next message
The setting that controls the context path is the "Context Root"
property on the Web Project Settings page of the project's Properties
dialog. However, "Web module name" likely refers to the "deploy-name"
attribute found in the ".settings/org.eclipse.wst.common.component" file
of the project. Note that the "deploy-name" value needs to stay in sync
with the project name, or there will be bigger problems with the project.
Does "does not launch my initial web page" mean the browser doesn't
appear or the browser appears but unexpected output occurs?
Larry
> down)?
> Thanks in advance.
> Whatty
>> Good morning,
>> 3.4.1?
>> Thanks in advance.
>> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229713 is a reply to message #229697] Thu, 26 March 2009 13:09 Go to previous messageGo to next message
The browser does not appear
I am changing the name in the settings, I guess it was silly to use an
embedded space way back when I first created the project, and I will how
that works.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:gqg6ij$n67$1@build.eclipse.org...
> The setting that controls the context path is the "Context Root" property
> on the Web Project Settings page of the project's Properties dialog.
> However, "Web module name" likely refers to the "deploy-name" attribute
> found in the ".settings/org.eclipse.wst.common.component" file of the
> project. Note that the "deploy-name" value needs to stay in sync with the
> Does "does not launch my initial web page" mean the browser doesn't appear
> Cheers,
> Larry
>> the Web module name (example "project<sp>") and it complains about not
>> being able to find the correct folder, which is related to the context
>> entry in the server.xml in the server local-config
>> source.
>> it down)?
>> Thanks in advance.
>> Whatty
>>> Good morning,
>>> AJAX / RichFaces) it sometimes does not launch my initial web page.
>>> 3.4.1?
>>> Thanks in advance.
>>> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229721 is a reply to message #229713] Thu, 26 March 2009 14:11 Go to previous messageGo to next message
If the server is already started, will "Run on server" make the browser
appear?
Larry
> that works.
>> Cheers,
>> Larry
>>> source.
>>> it down)?
>>> Thanks in advance.
>>> Whatty
>>>> Good morning,
>>>> 3.4.1?
>>>> Thanks in advance.
>>>> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229792 is a reply to message #229721] Sun, 29 March 2009 17:14 Go to previous messageGo to next message
I have removed the embedded space in the ".settings" property file and it
still does not launch the initial page sometimes.
However, as per your suggestion, if the server is started, and I ask for
"Run on server" again the browser does in fact appear.
This is workable for now but otherwise is a minor PITA (Pain in the A$$)
news:gqggg9$n8m$1@build.eclipse.org...
> appear?
> Cheers,
> Larry
>> that works.
>>> project.
>>> Cheers,
>>> Larry
>>>> source.
>>>> track it down)?
>>>> Thanks in advance.
>>>> Whatty
>>>>> Good morning,
>>>>> 3.4.1?
>>>>> Thanks in advance.
>>>>> Whatty
Re: Upgrade to 3.4.1 - Run on server no longer launches initial page - context name with embedded sp [message #229886 is a reply to message #229792] Tue, 31 March 2009 09:09 Go to previous message
I have seen this behavior recently too, but haven't had time to
investigate. I'm not sure what has changed.
Larry
>> appear?
>> Cheers,
>> Larry
>>> that works.
>>>> project.
>>>> Cheers,
>>>> Larry
>>>>> source.
>>>>> track it down)?
>>>>> Thanks in advance.
>>>>> Whatty
>>>>>> Good morning,
>>>>>> 3.4.1?
>>>>>> Thanks in advance.
>>>>>> Whatty
Previous Topic:Facet version not detected correctly
Next Topic:change XML schema prefix impossible using WTP XML model
Current Time: Sat Jul 26 10:26:31 EDT 2025
Powered by FUDForum. Page generated in 0.29486 seconds
