Home » Modeling » GMF (Graphical Modeling Framework) » Re: Properties not displayed after adding an ecore to genmodel
Re: Properties not displayed after adding an ecore to genmodel [message #229420] Mon, 11 May 2009 12:09 Go to next message
Aurelien,
It's best to ask on the GMF newsgroup, which I've added to the "to" list
of the reply, so no need to repost.
Aurelien Pupier wrote:
> The properties relative to EObject which are all in the same .ecore
> are not displayed in the properties view.
> How did I arrived to that?
> 1. I'd already a project with multiple .ecore and one .genmodel which
> mix up them alltogether. There is a diagram which display what I want
> (generated with a beautiful gmfmap, gmftool, ...)
> 2. I created a new .ecore with some EClass
> 3. reloaded .genmodel with adding the new .ecore and regenerated the code
> 4. modify the gmfmap and gmftool to include a graphical part of the
> EObject
> 5. regenerated gmfgen and regenerated code from it
> Now I have my new type of element displayed at the right place in my
> diagram but when I'm selecting one of them, nothing appears in the
> properties view it is only changing the title name.
> Thanks for your help,
> Aurélien Pupier
Re: Properties not displayed after adding an ecore to genmodel [message #229701 is a reply to message #229420] Tue, 12 May 2009 11:21 Go to previous messageGo to next message
Hello Aurelien,
Are you sure you've regenerated EMF edit/editor code (not only EMF model
code) using updated genmodel?
Can you see proper properties if you select this new element instance in
EMF-generated tree editor?
Alex Shatalin
Re: Properties not displayed after adding an ecore to genmodel [message #444583 is a reply to message #229701] Fri, 31 July 2009 13:29 Go to previous messageGo to next message
Dear Alex, dear Ed,
I have the same problem: I just updated some attributes in my ecore and
genmodel. Then I updated also my mapping model and the gmfgen model.
Then I regenerated everything (model code, edit code, editor code,
diagram code).
All code is compile error free, but in the diagram I don't see any
properties of selected elements.
If I open a model with the generated EMF editor, all properties are
visible there.
What could be wrong?
Hauke
Alex Shatalin schrieb:
> Hello Aurelien,
> code) using updated genmodel? Can you see proper properties if you
> select this new element instance in EMF-generated tree editor?
> Alex Shatalin
Re: Properties not displayed after adding an ecore to genmodel [message #467962 is a reply to message #444583] Mon, 03 August 2009 08:58 Go to previous messageGo to next message
Hello Hauke,
Are you sure you selecting exactly the same element on a diagram and in EMF
model tree? Is it a link or a node?
Alex Shatalin
Re: Properties not displayed after adding an ecore to genmodel [message #521089 is a reply to message #444583] Tue, 16 March 2010 08:53 Go to previous message
Originally posted by: mail.hamburg.googlemail.com
Hello Hauke,
had that issue since GMF 2.2. A workaround you can try (which helped me
out at least) is here:
http://sdqweb.ipd.kit.edu/wiki/Property_Sheet_remains_empty_ with_GMF_2.2
(I needed to apply only the first part of the workaround).
Hope that helps, good luck!
> visible there.
> Cheers,
> Hauke
Previous Topic:Type-Usage-Concept
Next Topic:Create GMFGen using multiple ecore models / genmodels
Current Time: Sat Jul 26 14:52:07 EDT 2025
Powered by FUDForum. Page generated in 0.07577 seconds
