Home » Eclipse Projects » GEF » Draw2D zooming
Draw2D zooming [message #228792] Wed, 10 January 2007 05:24 Go to next message
Hi all,
I a m trying to use the Zoom capability provided by draw2d. I found some
examples in the GEF examples plugin. It works fine but i still have a
problem. In these example no ScalabledLayerdPane are used. Instead of this
a ZoomContainerFigure is created and ovveride the paintClientArea method
to take into account a zoom factor using a scaled graphic.
I tried to use instead of this the provided class ScalableLayeredPane but
using this figure i can't get anything displayed.
Does anybody used it and have you a sample program showing how to use it ??
Manu
Re: Draw2D zooming [message #228905 is a reply to message #228792] Thu, 11 January 2007 08:34 Go to previous messageGo to next message
Originally posted by: news.madlener.online.de
Hi Manu,
i found this in the LogicExample:
LogicEditor line 407:
protected void configureGraphicalViewer() {
super.configureGraphicalViewer();
ScrollingGraphicalViewer viewer =
(ScrollingGraphicalViewer)getGraphicalViewer();
ScalableFreeformRootEditPart root = new ScalableFreeformRootEditPart();
List zoomLevels = new ArrayList(3);
zoomLevels.add(ZoomManager.FIT_ALL);
zoomLevels.add(ZoomManager.FIT_WIDTH);
zoomLevels.add(ZoomManager.FIT_HEIGHT);
root.getZoomManager().setZoomLevelContributions(zoomLevels);
IAction zoomIn = new ZoomInAction(root.getZoomManager());
IAction zoomOut = new ZoomOutAction(root.getZoomManager());
getActionRegistry().registerAction(zoomIn);
getActionRegistry().registerAction(zoomOut);
getSite().getKeyBindingService().registerAction(zoomIn);
getSite().getKeyBindingService().registerAction(zoomOut);
hope this is of any help to you ;)
cheers
Oliver
MaManu wrote:
> Hi all,
> this a ZoomContainerFigure is created and ovveride the paintClientArea
> method to take into account a zoom factor using a scaled graphic.
> but using this figure i can't get anything displayed.
> Thanks
> Manu
Re: Draw2D zooming [message #228919 is a reply to message #228905] Thu, 11 January 2007 09:23 Go to previous messageGo to next message
Thanks Oliver,
I also founded this piece of code in the logic Example this morning and
solved my problem.
Manu
Re: Draw2D zooming [message #228927 is a reply to message #228919] Thu, 11 January 2007 09:49 Go to previous messageGo to next message
>>>>> manuel.selva@st.com (Manu):
> and solved my problem.
Is your zoom combo box enabled?
Mine isn't (I've also copied from the logic Example today).
But I did succeed in getting the zoom in and zoom out toolbuttons.
Re: Draw2D zooming [message #228943 is a reply to message #228927] Thu, 11 January 2007 10:10 Go to previous message
>>>>> Steinar Bang <sb@dod.no>:
I've now successfully enabled the zoom combo box.
I had to implement the ERDiagramEditor#getAdapter() method,
as defined in the IBM "Using the Graphical Editor Framework
and the Eclipse Modeling Framework", on page 146/147 (and in the
LogicEditor of the example, for that matter. But the redbook actually
_explains_ it...:-) ).
The redbook can be found at:
http://www.redbooks.ibm.com/redbooks/pdfs/sg246302.pdf
Previous Topic:Problem: replacing root edit part gives blank white editor
Next Topic:Draw a border around an ellipse figure
Current Time: Sun Jun 08 22:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.26888 seconds
