Home » Modeling » GMF (Graphical Modeling Framework) » how to show List in a property view
how to show List in a property view [message #228840] Tue, 05 May 2009 05:19 Go to next message
I am trying to build an application in which there is an EClass which has
an EReference to itself. For e.g.
Fruit(EClass)
|--->name(EAttribute)(EType is EString)
|--->otherFruits(EReference) (and its EType is Fruit)
Basically what I want is when i drop a node FRUIT on GMF Editor, then its
OTHERFRUITS property should show list of other FRUIT nodes already
present. But when i am implementing it actually, only NAME property is
coming up in properties view not OTHERFRUITS property. What shall I do?
Please help me.
Akansha
Re: how to show List in a property view [message #228864 is a reply to message #228840] Tue, 05 May 2009 05:31 Go to previous messageGo to next message
Originally posted by: tobk42.gmx.de
Hello Akansha,
you should check your genmodel file (the file generated from the ecore
file). There should be an entry for each feature of each class where you
can set whether it should be displayed (read-only or editable) in the
properties sheet. Afterwards, you'll have to regenerate the edit code
(right-clicking on the package element in the genmodel file).
Tobias
Akansha schrieb:
> Hi, I am trying to build an application in which there is an EClass
> which has an EReference to itself. For e.g.
> Fruit(EClass) |--->name(EAttribute)(EType is EString)
> its OTHERFRUITS property should show list of other FRUIT nodes already
> Please help me.
> Thanks, Akansha
Re: how to show List in a property view [message #228888 is a reply to message #228864] Tue, 05 May 2009 06:34 Go to previous messageGo to next message
Thanks a lot. It worked :D
Re: how to show List in a property view [message #229106 is a reply to message #228888] Thu, 07 May 2009 04:34 Go to previous messageGo to next message
Consider the following situation:
Service
|---type:Type
and Type can be any of four TypeA, TypeB, TypeC or TypeD EClasses. How to
do that in ECore file. Any pointers.
Akansha
Re: how to show List in a property view [message #229114 is a reply to message #229106] Thu, 07 May 2009 04:42 Go to previous messageGo to next message
I've already noticed your other thread, and if I understand you correct
this should be the default behaviour...
I understood the following:
- you have a number of "Type*" nodes on your canvas, inheriting from a
common supertype "Type"
- you have another element with a reference of type "Type"
- you want the property sheet to display a list of all available
instances of Type (including instance of subclasses)
What is currently displayed when you expand the combo box for that
property? Is Type really a supertype of the four Type*?
Tobias
Akansha schrieb:
> Service
> |---type:Type
> to do that in ECore file. Any pointers.
> Akansha
Re: how to show List in a property view [message #229137 is a reply to message #229114] Thu, 07 May 2009 06:46 Go to previous messageGo to next message
Actually structure of my ecore file was different but i modified it
according to what you mentioned and its showing up in list now. But one
more problem is there, apart from EClasses i have EEnum (containing EENum
Literals) also which i want to show in that list. So what i did is created
an EClass and added one EAttribute in it with its Etype referring to EENum
and set its super type as TYPE. But the property list is not showing the
EEnum literals. Where i am wrong ?
Re: how to show List in a property view [message #229145 is a reply to message #229137] Thu, 07 May 2009 07:23 Go to previous messageGo to next message
Hello Akansha,
again I am not sure whether I understood you correctly. What you want is
that for that attribute Operation.type both all instances of Type
(including TypeA etc.) are displayed, /and/ the literals of that
enumeration, right?
What exactly do you want to achieve? Shall the enums be predefined
values for types (like primitive types in Java as opposed to Java
classes)? I don't think this is possible this way. Maybe you could
create a number of Type instances on diagram creation, representing the
values of the enumeration using a fifth Type type which has no graphical
representation in the diagram.
Tobias
> EENum Literals) also which i want to show in that list. So what i did is
> created an EClass and added one EAttribute in it with its Etype
> referring to EENum and set its super type as TYPE. But the property list
> is not showing the EEnum literals. Where i am wrong ?
Re: how to show List in a property view [message #229153 is a reply to message #229145] Thu, 07 May 2009 07:35 Go to previous messageGo to next message
Another Idea: In your .edit plugin, you can change the method
addTypePropertyDescriptor of class OperationItemProvider and overwrite
the method getComboBoxObjects of the created ItemPropertyDescriptor. I
am not sure how exactly to do this, but this way you could add all the
Type elements to the list, as well as a number of fixed types --
however, this way the attribute Operation.type would have to be of type
String or Object...
Hope this helps,
Tobias
Tobias schrieb:
> Hello Akansha,
> enumeration, right?
> Regards,
> Tobias
>> one more problem is there, apart from EClasses i have EEnum
>> (containing EENum Literals) also which i want to show in that list. So
>> what i did is created an EClass and added one EAttribute in it with
>> its Etype referring to EENum and set its super type as TYPE. But the
>> property list is not showing the EEnum literals. Where i am wrong ?
Re: how to show List in a property view [message #229161 is a reply to message #229145] Thu, 07 May 2009 07:49 Go to previous messageGo to next message
You understood me correctly. What I want is that for attribute
Operation.type both all instances of Type (including TypeA etc.) are
displayed and the predefined literals of that enumeration. For better
understanding you can consider that java primitive types constitute Enum
literals and Java classes are other Types (TypeA, TypeB,etc). So what i
want is the display of Java classes as well as primitive java types in the
list.
Re: how to show List in a property view [message #229184 is a reply to message #229161] Thu, 07 May 2009 09:23 Go to previous messageGo to next message
I think you should have a look at how this was realized in the EMF ecore
editor, since there you have exactly the same functionality: A dropdown
list featuring a number of predefined classes (such as EObject, EEList,
EJavaObject, ...) and your own classes. I think, they are using Strings
as representation for these, and not references to the actual objects.
Maybe you can build upon this...
Tobias
Akansha schrieb:
> the list.
Re: how to show List in a property view [message #229270 is a reply to message #229184] Fri, 08 May 2009 01:47 Go to previous messageGo to next message
Is it possible to make editable dropdown i.e. if user does not want to
select from list he can write his own value in dropdown.
Akansha
Re: how to show List in a property view [message #229278 is a reply to message #229270] Fri, 08 May 2009 05:21 Go to previous message
Any body there to reply :(
Previous Topic:How to get the EditPart of a Node from its View object?
Next Topic:How to know if a diagram is validated OK
Current Time: Fri Jul 25 10:23:23 EDT 2025
Powered by FUDForum. Page generated in 0.10692 seconds
