Home » Newcomers » Newcomers » Project Type does not appear in the project wizard.
Project Type does not appear in the project wizard. [message #228594] Tue, 21 August 2007 10:34 Go to next message
Originally posted by: andrew.meng.capitaloneauto.com
I just download IBM java-com bridge plugin and unzip all features and
plugin files into eclipse(3.3) root folder. However I could not find the
"Java-COM" bridge project type when I try to create a new project from
the wizard. It might be related to some general issue related to plugin.
Can anyone shed any light on this?
Thanks a lot!
Andrew
Re: Project Type does not appear in the project wizard. [message #228815 is a reply to message #228594] Wed, 22 August 2007 09:21 Go to previous messageGo to next message
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Go to the Help->Software Updates->Manage Configuration and check, if tge
plugin has been loaded...
HTH,
Chris
Andrew pisze:
> Hello,
> Thanks a lot!
> Andrew
Re: Project Type does not appear in the project wizard. [message #228832 is a reply to message #228815] Wed, 22 August 2007 09:26 Go to previous message
Originally posted by: dmsubs.NOSPAM.consertum.com
Don't forget that after unzipping plugins into an installation, you need to
restart Eclipse with the -clean option, which causes it to reload its plugin cache.
Derek
> HTH,
> Chris
> Andrew pisze:
>> Hello,
>> the "Java-COM" bridge project type when I try to create a new project
>> from the wizard. It might be related to some general issue related to
>> plugin. Can anyone shed any light on this?
>> Thanks a lot!
>> Andrew
Previous Topic:Unhandled event loop exception
Next Topic:problem with creation of markers
Current Time: Fri Sep 12 17:46:01 EDT 2025
Powered by FUDForum. Page generated in 0.07698 seconds
