Home » Language IDEs » ServerTools (WTP) » marker & squiggle creation problem after XML validation
marker & squiggle creation problem after XML validation [message #228729] Tue, 10 March 2009 10:18 Go to next message
Dear All,
I extended XML editor. Everything worked fine before I refactored the
project file layout. The XML validation still works fine. After the
validation, the problem marker is created in vertical ruler (which is
fine), but the red squiggle isn't created as expected.
Without the red wave line, we can't bring up the quick-fix suggestions. It
seems that WTP XML editor doesn't set IMarker.CHAR_START and
IMarker.CHAR_END. Instead, it sets the column and row number. So my
questions:
How could a problem marker infer the text that should be underlined with
squiggle?
How to debug and recover the squiggle creation?
Any suggestion or clue is highly appreciated! Thank you so much!
Best Regards,
Frank Du
Re: marker & squiggle creation problem after XML validation [message #228749 is a reply to message #228729] Tue, 10 March 2009 15:52 Go to previous messageGo to next message
> It seems that WTP XML editor doesn't set IMarker.CHAR_START and
> questions:
> squiggle?
The values aren't something that the editor affects, it's instead
the particular validator that created the problem/message that is
responsible. What is the problem/message being created?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: marker & squiggle creation problem after XML validation [message #228817 is a reply to message #228749] Wed, 11 March 2009 14:23 Go to previous messageGo to next message
Yes, a validator creates the markers. It's a subclass of
AbstractNestedValidator. For instance, the problem marker is:
message: DataSetVersion must be equal to '2.5.4'.
lineNumber: 9
severity: 1
toString(): ------ERROR-----: InvalidDataSetVersion: DataSetVersion must
be equal to '2.5.4'. (line 9, column 19)
The error marker appears in the vertical ruler. The squiggle doesn't show
up in the editor.
Any way do locate the issue?
Thank you so much,
Frank
Re: marker & squiggle creation problem after XML validation [message #228985 is a reply to message #228817] Sat, 14 March 2009 20:36 Go to previous message
Originally posted by: valentinbaciu.hotmail.com
Frank, to understand how the XML validator deals with squiggles have a look
at these two classes:
org.eclipse.wst.xml.core.internal.validation.eclipse.XMLMess ageInfoHelper
org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceV alidator
XMLMessageInfoHelper adds extra information about the squiggle strategy to
use and DelegatingSourceValidator
computes more precise squiggle location (offset, length).
Hope this helps, Valentin
"Frank Du" <du.qixing@gmail.com> wrote in message
news:7f0518055a0be20f4b74a0e5cbab836a$1@www.eclipse.org...
> lineNumber: 9
> severity: 1
> up in the editor.
> Thank you so much,
> Frank
>> The values aren't something that the editor affects, it's instead the
Previous Topic:[XSLT Tools] XML Catalog in xsl:include
Next Topic:content assist hot key does not work in my customized xml editor on Eclipse 3.4
Current Time: Wed Jul 23 21:34:49 EDT 2025
Powered by FUDForum. Page generated in 0.06354 seconds
