Eclipse won't start up after update [message #228587] |
Mon, 02 March 2009 15:38  |
I was running Eclipse WTP 3.0.3 fine for months. Today I decided to update
to 3.0.4. The update went fine and it asked me to restart as usual.
However eclipse will now no longer start since the update.
The small screen that usually shows Eclipse starting up is displayed for
only a split second and then goes away. Also, the log file at
<workspace_dir>/.metadata/.log is not updated from the attempted start.
Not sure if there are any other log files to look at.
The last entry in the log is this:
!SESSION 2009-03-01 15:25:45.860
eclipse.buildId=M20080911-1700
java.version=1.6.0_07
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -data
C:\eclipse_workspaces\eclipse_wtp_main -showlocation
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-03-01
15:28:36.203
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-01 15:28:36.203
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-03-01 15:29:07.736
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-01 15:29:07.736
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core
1.1.203.v200802140626 to requiredCapability:
osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui
1.0.305.v200802142230 to requiredCapability:
with many more of the "requiredCapability" lines.
This happened to me last fall also, and I then just re-installed Eclipse
from scratch (since I couldn't start Eclipse to revert to the old
configuration), but thought I'd now try and see if there is a solution, or
maybe a bug that the community could be made aware of.
Joe
FUDForum. Page generated in 0.24824 seconds
