| Programmatically launching web service explorer [message #227811] | Fri, 13 February 2009 10:30  |  |
| Eclipse User  |  |  |  |  | Originally posted by: marius.eich.gmx.de
 I'd like to know if there is a way of programmatically launching the web
 service explorer from another plugin. I haven't found any information about
 this yet. I tried to launch the explorer by running
 org.eclipse.wst.ws.internal.explorer.action.LaunchWSEAction but there is an
 access restriction. Any ideas?
 Thanks in advance and best regards
 Marius Eich
| Re: Programmatically launching web service explorer [message #228865 is a reply to message #228630] | Thu, 12 March 2009 15:35  |  |
| Eclipse User  |  |  |  |  | Hi,
 Sorry for taking so long to respond.  I'm not sure why this doesn't
 work.  I can't find any places in WTP where we use this option.
 Try setting a breakpoint in the LaunchOptionsManager.loadOptions method
 to see what's going on there.  Make sure the bindingNameStrings array
 gets populated with your binding name, and then follow the code into
 WSDLPerspective.preselectServiceOrBinding.
 If you find a bug with the code please open a bug, and feel free to
 contribute a patch.
 I hope this helps,
 Mark
 Marius Eich wrote:
 > Hi again,
 > now that I managed to launch the web service explorer from my plugin, I'm
 > trying to launch it with a binding already selected. There is no problem in
 > preselecting the correct wsdl by setting the wsdl location as launchoption
 > with the key LaunchOptions.WSDL_URL.
 > Now I thought that I could preselect a binding belonging to this wsdl by
 > adding the wsdl option and an option with the key
 > LaunchOptions.BINDING_NAME_STRING and the correct binding name as value. But
 > that doesn't work. After launching the explorer, the wsdl is selected and
 > one can select a binding from the binding list. Can anyone tell me what I
 > did wrong or where to find an example for this?
 > Thanks and best regards
 > Marius Eich
 > "Marius Eich" <marius.eich@gmx.de> schrieb im Newsbeitrag
 > news:gnmltd$emv$1@build.eclipse.org...
 >> Hi Mark,
 >> thank you very much. It worked.
 >> Best regards
 >> Marius
 >> "Mark Hutchinson" <mahutch@ca.ibm.com> schrieb im Newsbeitrag
 >> news:gnhkv5$3io$1@build.eclipse.org...
 >>> Try using the WSExplorerLauncherCommand.
 >>> There is an example of this in the WSEGenerateCommand (found in the
 >>> org.eclipse.jst.ws.consumption.ui plugin)
 >>> Marius Eich wrote:
 >>>> Hello,
 >>>> about this yet. I tried to launch the explorer by running
 >>>> an access restriction. Any ideas?
 >>>> Marius Eich
FUDForum. Page generated in 0.07917 seconds
