Home » Modeling » GMF (Graphical Modeling Framework) » GMF Tutorial , Dashboard
GMF Tutorial , Dashboard [message #228525] Thu, 30 April 2009 10:02 Go to next message
hi guys i am working in GMF in 15 min Tutorial :
http://www.ibm.com/developerworks/opensource/library/os-ecl- gmf/
and have few Problems:
first i downloaded the example of the Tutorialpage at the end , but i dont
know how to make it run !!!
seconde in the tutorial there was written if i want to enter the dashboard
i have to go :
Window > Show View > Other > GMF Dashboard
i tried this but after
Window > Show View > Other i find No GMF Dashboard :(
i downloaded gmf-sdk-2.1.3 unzipped it and put the files in the proper
ecliupse File , i have GEF running from a time and it works , and i have
EMF too ...
what can be the problem ?
somebody have a src example that he can send me , just to see if it is
working
here is my email address elia-work@gmx.de
i will really appreciate any help because i am having really problems here.
thanks a lot
Elia
Re: GMF Tutorial , Dashboard [message #228541 is a reply to message #228525] Thu, 30 April 2009 10:15 Go to previous messageGo to next message
Originally posted by: rodrigo.garcia.kotasoft.com
Take a look at this demo:
http://live.eclipse.org/node/359
And you can download examples from dev.eclipse.org /cvsroot/modeling
Regarding to the GMF Dashboard I think you need to download GMF SDK and
GMF Runtime
Best regards
> dont know how to make it run !!!
> dashboard i have to go :
> i tried this but after Window > Show View > Other i find No GMF
> Dashboard :(
> EMF too ...
> working
> thanks a lot
> Elia
Re: GMF Tutorial , Dashboard [message #228549 is a reply to message #228541] Thu, 30 April 2009 11:06 Go to previous messageGo to next message
hi thanks you for the vid ,
i have downloaded the
gmf-runtime-2.1.3
and
gmf-sdk-2.1.3
and i still not able to start a GMF Project ...
can somebody tell me which software i need more??
thanks a lot
Re: GMF Tutorial , Dashboard [message #228557 is a reply to message #228549] Thu, 30 April 2009 12:06 Go to previous messageGo to next message
What Eclipse distro are you using?
I'm using eclipse RCP/PDE
> gmf-runtime-2.1.3
> and
> gmf-sdk-2.1.3
> thanks a lot
Re: GMF Tutorial , Dashboard [message #228564 is a reply to message #228557] Thu, 30 April 2009 12:15 Go to previous messageGo to next message
Or you can download eclipse Modeling
>> gmf-runtime-2.1.3
>> and
>> gmf-sdk-2.1.3
>> thanks a lot
Re: GMF Tutorial , Dashboard [message #228773 is a reply to message #228525] Mon, 04 May 2009 11:25 Go to previous message
Hi Elia,
the tutorial you are using is quite old, so things may have changed. I
would suggest using the tutorial at
http://wiki.eclipse.org/index.php/GMF_Tutorial instead.
Example code for this tutorial is available via CVS:
:pserver:anonymous@dev.eclipse.org:/cvsroot/modeling
and from there the following projects:
org.eclipse.gmf/examples/org.eclipse.gmf.examples.mindmap.*
And to make your life easier, you could download and use the integrated
"Eclipse Modeling Tools" package from http://www.eclipse.org/downloads/.
It has EMF, GMF and all dependencies already installed.
HTH,
Marco
> Dashboard :(
> EMF too ...
> working
> thanks a lot
> Elia
Previous Topic:getSelection() returns null ?!?!
Next Topic:Don't want the generated diagram creation wizard
Current Time: Fri Nov 07 19:19:23 EST 2025
Powered by FUDForum. Page generated in 0.04744 seconds
