Home » Language IDEs » ServerTools (WTP) » Create a WTP XML Node from an XML string
Create a WTP XML Node from an XML string [message #228524] Mon, 02 March 2009 09:49 Go to next message
I'm working on an XML editor based on WTP XML Editor, so I have to work with
a WTP DOM.
The problem:
I have to create a Node from an XML String and insert the node to the WTP
DOM.
I can create document from a String but it won't be a WTP Document, so when
I try to insert the first child of the newly created DOM to the WTP DOM I
got the following exception:
java.lang.ClassCastException: org.apache.xerces.dom.DeferredElementImpl
cannot be cast to org.eclipse.wst.xml.core.internal.document.NodeImpl
at
org.eclipse.wst.xml.core.internal.document.NodeContainer.ins ertBefore(NodeContainer.java:269)
at
org.eclipse.wst.xml.core.internal.document.ElementImpl.inser tBefore(ElementImpl.java:693)
at
org.eclipse.wst.xml.core.internal.document.NodeContainer.app endChild(NodeContainer.java:129)
Code I use to create the DOM:
public static Document stringToDom(String xmlSource) throws SAXException,
ParserConfigurationException, IOException {
DocumentBuilderFactory factory = DocumentBuilderFactory.newInstance();
DocumentBuilder builder = factory.newDocumentBuilder();
return builder.parse(new InputSource(new StringReader(xmlSource)));
I browsed the wst.core code but can't find any solution.
Can anybody help me?
Istvan
Re: Create a WTP XML Node from an XML string [message #228540 is a reply to message #228524] Mon, 02 March 2009 10:58 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Have you tried the cloneNode() method?
I think the problem you are going to run into though is that you are
going from two different DOM implementations. So what you might have to
do is create a custom Clone Node method that takes the input of the
Xerces DOM node, and recreates a WTP DOM node, and returns the WTP DOM
node as it's result.
Unfortunately, WTP DOM is known not to be a 100% complete implementation
of DOM, so there are edge cases where it has problems. This appears to
be one.
Dave
Istvan wrote:
> Hello,
> with a WTP DOM.
> The problem:
> WTP DOM.
> when I try to insert the first child of the newly created DOM to the WTP
> DOM I
> at
> at
> at
> SAXException, ParserConfigurationException, IOException {
> Istvan
Re: Create a WTP XML Node from an XML string [message #228548 is a reply to message #228540] Mon, 02 March 2009 11:08 Go to previous messageGo to next message
David,
I suppose one could create a WTP DOM Document and use importNode on the
root element to clone, or would that result in cast exceptions as well?
> to do is create a custom Clone Node method that takes the input of the
> implementation of DOM, so there are edge cases where it has problems.
> This appears to be one.
> Dave
> Istvan wrote:
>> Hello,
>> work with a WTP DOM.
>> The problem:
>> WTP DOM.
>> so when I try to insert the first child of the newly created DOM to
>> the WTP DOM I
>> org.apache.xerces.dom.DeferredElementImpl cannot be cast to
>> at
>> at
>> at
>> Thanks,
>> Istvan
Re: Create a WTP XML Node from an XML string [message #228556 is a reply to message #228548] Mon, 02 March 2009 11:43 Go to previous messageGo to next message
Thanks for quick replies.
I checked this just now, normal cloneNode does not work, it produces the
same Exception than without using cloneNode.
Custom cloning: I thought there is a "more standard" way than doing this but
I think I will choose it, it is sure it will work.
Although, I would give a chance to the other solution.
Ed, how can I create a WTP DOM?
Can I force the stringToDom method below to create a WTP DOM?
Istvan
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:goh09i$4bl$1@build.eclipse.org...
> David,
>> be one.
>> Dave
>> Istvan wrote:
>>> Hello,
>>> with a WTP DOM.
>>> The problem:
>>> WTP DOM.
>>> DOM I
>>> at
>>> at
>>> at
>>> Thanks,
>>> Istvan
Re: Create a WTP XML Node from an XML string [message #228565 is a reply to message #228556] Mon, 02 March 2009 12:22 Go to previous messageGo to next message
Istvan,
I assume there's a factory somewhere to create a Document. But then,
I'd have assumed there'd be something to create a instance from a Reader
or an InputStream...
> the same Exception than without using cloneNode.
> this but I think I will choose it, it is sure it will work.
> Istvan
>> David,
>> the root element to clone, or would that result in cast exceptions as
>> well?
>>> have to do is create a custom Clone Node method that takes the input
>>> of the Xerces DOM node, and recreates a WTP DOM node, and returns
>>> the WTP DOM node as it's result.
>>> problems. This appears to be one.
>>> Dave
>>> Istvan wrote:
>>>> Hello,
>>>> The problem:
>>>> the WTP DOM.
>>>> the WTP DOM I
>>>> at
>>>> at
>>>> at
>>>> Thanks,
>>>> Istvan
Re: Create a WTP XML Node from an XML string [message #228573 is a reply to message #228565] Mon, 02 March 2009 13:13 Go to previous messageGo to next message
Ed Merks wrote:
> Istvan,
There is...but it does not implement the Standard JAXP Document
builder...with that said the following code will simulate it.
public Document load(java.net.URL url) throws DOMTestLoadException {
IStructuredDocument document = null;
Document doc = null;
IStructuredModel model = null;
try {
FileInputStream file = new FileInputStream(url.getPath());
InputStream inputStream = Utilities.getMarkSupportedStream(file);
ModelHandlerForXML xmlModelHandler = new ModelHandlerForXML();
IDocumentLoader loader = xmlModelHandler.getDocumentLoader();
document =
(IStructuredDocument)loader.createNewStructuredDocument("/home/dcarver/test.xml ",
inputStream, EncodingRule.FORCE_DEFAULT);
IModelLoader xmlModelLoader = xmlModelHandler.getModelLoader();
model = xmlModelLoader.createModel(document, url.getPath(),
xmlModelHandler);
catch (IOException e) {
e.printStackTrace();
} catch (Exception e) {
String text = model.getStructuredDocument().getText();
IDOMModel docModel = (IDOMModel)model;
doc = (Document)docModel.getDocument();
return doc;
That is some sample of how to create an WTP DOM from an input file.
Dave
Re: Create a WTP XML Node from an XML string [message #228581 is a reply to message #228573] Mon, 02 March 2009 15:35 Go to previous messageGo to next message
In the meantime I implemented a simple cloneNode method, it works.
I also tested the code Dave posted: I changed it to receive an xml-string
and build a document from it. Inserting the result as a child of a WTP node
works, but I get errors when I try to format the node using
xmlNodeActionManager.reformat(node, true).
Maybe I will debug this later, but for now I will use the cloneNode method.
Thanks a lot for both of you.
Istvan
Re: Create a WTP XML Node from an XML string [message #228597 is a reply to message #228581] Mon, 02 March 2009 22:27 Go to previous messageGo to next message
Istvan,
If you can please open a bug report against the existing wst.xml
component, and report the issue with the cloneNode method.
It should take any DOM interface and clone the node, and not be dependent.
Dave
> xml-string and build a document from it. Inserting the result as a child
> of a WTP node works, but I get errors when I try to format the node
> using xmlNodeActionManager.reformat(node, true).
> Istvan
Re: Create a WTP XML Node from an XML string [message #228618 is a reply to message #228597] Tue, 03 March 2009 01:42 Go to previous message
I just skimmed read the specifics of this thread, but if you have
specific problems with 'cloneNode', you might document them in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156293
Previous Topic:Password protect 3.4.1 infocenter
Next Topic:Eclipse won't start up after update
Current Time: Fri Jul 25 21:41:09 EDT 2025
Powered by FUDForum. Page generated in 0.04320 seconds
