Home » Eclipse Projects » Buckminster dev » Non Java projects Proposal
| Non Java projects Proposal [message #22210] |
Mon, 21 July 2008 10:44  |
Hi everyone,
As you suggested Thomas I'm back on the forum. Our exchanges can be useful to everyone.
So let me sum up what happened the past days.
I wrote this proposal : http://wiki.eclipse.org/Non_Java_projects_Proposal and implemented it.
The *fetcher* actor depended on third-party library (activation.jar, tar.jar and bzip2.jar). Thomas suggested to use the ant plugin which provides those jars - what I did.
Thomas proposed me to extend the code Expander in org.eclipse.buckminster.ant.materializer as there's already a TarExpander and a TGZExpander, I could add the TBZ2Expander and propose them as extension points.
I can do this but the classes I already wrote to uncompress streams have added functionalities : they can flatten the hierarchy and filter the archive content. This would slightly modify the IExpander interface from :
public interface IExpander
void expand(InputStream input, File finalLocation, IProgressMonitor monitor) throws IOException, CoreException;
to something like
void setFlattenHierarchy(boolean flatten);
void setFilter(IArchiveFilter filter);
IArchiveFilter is another interface used to configure the filtering. Something like
public interface IArchiveFilter
void addIncludeFilter(String regex);
void addExcludeFilter(String regex);
If no one is against this proposal I'll implement the TBZ2Expander in org.eclipse.buckminster.ant.materializer and add an extension point for it.
Guillaume
| Re: Non Java projects Proposal [message #22582 is a reply to message #22210] |
Mon, 21 July 2008 14:43   |
Instead of defining yet another interface (IArchiveFilter), I propose
this definition
void setFileFilter(java.io.FileFilter filter);
FileFilter is a standard Java interface that can do the job.
http://java.sun.com/j2se/1.4.2/docs/api/java/io/FileFilter.h tml
Guillaume
Guillaume CHATELET wrote :
> Hi everyone,
> useful to everyone.
> to something like
> Something like
> Regards,
> Guillaume
| Re: Non Java projects Proposal [message #22844 is a reply to message #22802] |
Tue, 22 July 2008 05:10   |
I've finished implementing the changes :
- new project : org.eclipse.buckminster.executor
- new project : org.eclipse.buckminster.fetcher
Small modifications to projects :
org.eclipse.buckminster.download
org.eclipse.buckminster.core
The types .tar.bz2,.tbz2,.tb2,.tbz are now handled via the class org.eclipse.buckminster.ant.materializer.TBZ2Expander using extension point org.eclipse.buckminster.download.expanders.
My fetcher project is using the registered expanders to unzip, untar, untargz, and untarbz2 archives. Maybe we could add a 7z expander in the future as a third party feature (LGPL license).
How can I contribute my work to Buckminster ?
Guillaume
>>> this definition
>> I assume that this FileFilter will be fed with path names relative to
>> the archive root?
>> - thomas
> You're right. I presume FileFilter's interface is sufficient to provide
> include and exclude strategy on both directories and files.
> Guillaume
| Re: Non Java projects Proposal [message #22887 is a reply to message #22844] |
Tue, 22 July 2008 08:47   |
Hi Guillaume,
First of all. Great work! I really look forward to incorporating this
into Buckminster.
The best way for you to do that is to enter a Bugzilla enhancement
request and add the code as attachments (patches applicable to trunk
where possible). In the text, you should include a paragraph similar to
this:
"I hereby declare that I have authored the code, that I have the rights
to donate the code to Eclipse, and that I am submitting the code for
inclusion in future Eclipse releases under the Eclipse Public License"
Kind Regards,
Thomas Hallgren
> Regards,
> Guillaume
>>>> propose this definition
>>> the archive root?
>>> - thomas
>> provide include and exclude strategy on both directories and files.
>> Guillaume
| Re: Non Java projects Proposal [message #22931 is a reply to message #22887] |
Tue, 22 July 2008 09:14  |
Enhancement submitted !
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241657
- Guillaume
Thomas Hallgren wrote:
> Hi Guillaume,
> into Buckminster.
> this:
> Kind Regards,
> Thomas Hallgren
>> Regards,
>> Guillaume
>>>> to the archive root?
>>>> - thomas
>>> Guillaume
Current Time: Sun Nov 02 11:08:24 EST 2025
Powered by FUDForum. Page generated in 0.04504 seconds
