Home » Language IDEs » ServerTools (WTP) » Validator works with projects only?
Validator works with projects only? [message #228156] Sat, 21 February 2009 14:32 Go to next message
Hi all
I'm new here and I was investigating Bug 218101 - Allow validation of
files outside of projects. I found most of the validation classes are
using IProject. Also, the help context for adding folder or files rule in
validation preference says that "If you select a file or folder that is
outside of the scope of a project, the rule will not be activated."
Is the validator currently only work with projects?
Re: Validator works with projects only? [message #228433 is a reply to message #228156] Thu, 26 February 2009 15:52 Go to previous message
Currently the validation framework only works with resources inside of a
workspace, and so yes, all the resources need to be in projects.
The point of the bugzilla/request is to relax that restriction.
Previous Topic:How to disable webbrowser after launching my project?
Next Topic:User specified XML parser features and xinclude
Current Time: Sat Jul 26 07:45:50 EDT 2025
Powered by FUDForum. Page generated in 0.07195 seconds
