Home » Archived » BIRT » Several questions after two weeks of development
Several questions after two weeks of development [message #227909] Mon, 19 March 2007 10:28 Go to next message
Last two weeks I spent to develop custom datasource/datasets and design a
sample report. I don't need to publish my report but it should work in
Eclipse runtime.
So I have several question:
1 - why a jump by hyperlink takes so much time? It come up to time for
generating whole report. I have a single page HTML and can't understand
where viewer spent it. A profiler shows that most of time viewer do
"layout" - it is so strange because whole page already has been rendered.
2 - Is it possible to persist a report to HTML file with could be shown in
bowser without BIRT enviroment?
3 - I have tried to out my report to PDF but had an error :
root cause java.lang.LinkageError: loader constraint violation: when
resolving interface method
" org.eclipse.birt.report.engine.content.IStyle.getProperty(I) Lorg/w3c/dom/css/CSSValue; "
the class loader (instance of
org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current
class, org/eclipse/birt/report/engine/emitter/pdf/PDFEmitter$PDFRen der, and
org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved
class, org/eclipse/birt/report/engine/content/IStyle, have different Class
objects for the type org/w3c/dom/css/CSSValue used in the signature
at
org.eclipse.birt.report.engine.emitter.pdf.PDFEmitter$PDFRen der.newPage(PDFEmitter.java:652)
at
org.eclipse.birt.report.engine.emitter.pdf.PDFEmitter$PDFRen der.startContainer(PDFEmitter.java:585)
I have found similar case in
http://dev.eclipse.org/mhonarc/lists/birt-dev/msg07002.html with a solution
to trow out the xerces plugin. As result of applying this solution a lot
modules could not start but I got ability to see my report in PDF format. I
guess should be some less destructive sollution.
Re: Several questions after two weeks of development [message #228145 is a reply to message #227909] Mon, 19 March 2007 12:57 Go to previous messageGo to next message
> Eclipse runtime.
> at
> at
What version of BIRT are you using?
1 - How is the hyperlink built? verify that the rptdocument is not
getting overwritten if you are linking to it.
2 - Yes this is possible with the engine. This capability is not in the
BIRT Viewer though. Take a look at this example to see how to deploy the
engine in a servlet.
http://wiki.eclipse.org/index.php/Servlet_Example
Within the engine you can set an output filename instead of a stream.
I assume you want to do this in regards to question 1, where you then
could use the hyperlink editor to link directly to an html file.
3 - What install of BIRT did you use? The allinone?
Jason
Re: Several questions after two weeks of development [message #228192 is a reply to message #228145] Mon, 19 March 2007 13:54 Go to previous messageGo to next message
Thanks for fast reply,
Ups, BIRT version is 2.2M5 (see full description of configuration below)
- hyperlink built as "Internal bookmark" is chosen, URI value is
'row["Name"]'
> verify that the rptdocument is not getting overwritten if you are linking
> to it.
- how can I do it?
Configuration is:
eclipse-SDK-3.3M5eh-win32.zip
birt-report-framework-sdk-2.2M5.zip
emf-sdo-xsd-SDK-2.3.0M5.zip
emft-query-SDK-1.1M5.zip
emft-transaction-SDK-1.1M5.zip
emft-validation-SDK-1.1M5.zip
GEF-ALL-3.3M5.zip
GMF-sdk-2.0M5.zip
mdt-ocl-SDK-1.1M5.zip
uml2-SDK-2.1M5.zip
jre1.5.0_09
itext-1.4.6.jar
All extensions are linked to eclipse. If all extensions are installed all
together with eclipse - result the same. To get PDF I tried to "View report
as PDF" and ""View report in Web Viewer"->"Print as PDF" both failed. Full
exception:
19.03.2007 20:42:02 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask
doRun
SEVERE: Error happened while running the report.
java.lang.LinkageError: loader constraints violated when linking
org/w3c/dom/css/CSSValue class
at
at
at
org.eclipse.birt.report.engine.layout.area.impl.ContainerAre a.accept(ContainerArea.java:64)
at
org.eclipse.birt.report.engine.emitter.pdf.PDFEmitter.startP age(PDFEmitter.java:110)
at
org.eclipse.birt.report.engine.emitter.CompositeContentEmitt er.startPage(CompositeContentEmitter.java:284)
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.endPage( PDFPageLM.java:293)
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.java:216)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layoutReport(PDFReportLayoutEngine.java:61)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layout(PDFReportLayoutEngine.java:78)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:203)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:125)
at
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source)
at
Source)
at
org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.BirtRunAndRend erActionHandler.__execute(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
at
org.eclipse.birt.report.presentation.aggregation.layout.RunF ragment.doService(Unknown
Source)
at
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.service(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Unknow n
Source)
at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at
at
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
at
at
at
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
at
at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
at
at
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
at
at
at
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at
at
at
at
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:etmfcr$3mg$1@utils.eclipse.org...
>> Eclipse runtime.
>> in bowser without BIRT enviroment?
>> and the class loader (instance of
>> Class objects for the type org/w3c/dom/css/CSSValue used in the signature
>> at
>> at
>> solution to trow out the xerces plugin. As result of applying this
>> solution a lot modules could not start but I got ability to see my report
>> in PDF format. I guess should be some less destructive sollution.
> 1 - How is the hyperlink built? verify that the rptdocument is not getting
> Jason
Re: Several questions after two weeks of development [message #228208 is a reply to message #228192] Mon, 19 March 2007 14:11 Go to previous messageGo to next message
> 'row["Name"]'
>> to it.
> - how can I do it?
> Configuration is:
> GEF-ALL-3.3M5.zip
> GMF-sdk-2.0M5.zip
> uml2-SDK-2.1M5.zip
> jre1.5.0_09
> itext-1.4.6.jar
> exception:
> doRun
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> Eclipse runtime.
>>> at
>>> at
>> Jason
1 - You do not have to verify this if you are using an internal bookmark
(if you ever need to set the Window->preferences->report design->preview
always use external browsers to true and look at the url for __overwrite
=true).
The internal Bookmark should be very fast.
can you post the report?
3 - Can you log a bug for this. I did not have this problem with the
allinone.
Jason
Re: Several questions after two weeks of development [message #228567 is a reply to message #228208] Tue, 20 March 2007 11:28 Go to previous messageGo to next message
news:etmjnt$e0q$1@utils.eclipse.org...
> =true).
> allinone.
> Jason
1 - Report is attached. But it is using custom datasources with I have
implemented.
2 - Bug submited.
Re: Several questions after two weeks of development [message #228682 is a reply to message #228567] Tue, 20 March 2007 13:10 Go to previous messageGo to next message
>> =true).
>> allinone.
>> Jason
> implemented.
> 2 - Bug submited.
I wrote a sample report that uses expressions like you did.
I noticed that when using the WebViewer the bookmark drill happened
very fast. But when using the /run mapping it was slow (Which is what
happens when you preview in HTML (one html page)). As a work around you
can modify your web.xml from
<servlet-mapping>
<servlet-name>ViewerServlet</servlet-name>
<url-pattern>/run</url-pattern>
</servlet-mapping>
To
<servlet-mapping>
<servlet-name>EngineServlet</servlet-name>
</servlet-mapping>
I will submit a bug on this behavior.
Jason
Re: Several questions after two weeks of development [message #228863 is a reply to message #228682] Wed, 21 March 2007 07:00 Go to previous messageGo to next message
Thanks a lot.
news:etp4gi$5r2$1@utils.eclipse.org...
>>> =true).
>>> allinone.
>>> Jason
>> implemented.
>> 2 - Bug submited.
> I noticed that when using the WebViewer the bookmark drill happened very
> fast. But when using the /run mapping it was slow (Which is what happens
> when you preview in HTML (one html page)). As a work around you can
> <servlet-mapping>
> </servlet-mapping>
> To
> <servlet-mapping>
> </servlet-mapping>
> Jason
Re: Several questions after two weeks of development [message #228904 is a reply to message #228682] Wed, 21 March 2007 08:57 Go to previous messageGo to next message
I have changed <servlet-mapping> as you mentioned.
In internal viewer (tab preview) bookmark stoped work at all. The same
behavior when I use external browser IE7 or FireFox (IE7 also reports error:
"line 1, char 1, code 0 Erorr:Object expected" )
Best Kirill.
>>> =true).
>>> allinone.
>>> Jason
>> implemented.
>> 2 - Bug submited.
> <servlet-mapping>
> </servlet-mapping>
> To
> <servlet-mapping>
> </servlet-mapping>
> Jason
Re: Several questions after two weeks of development [message #228946 is a reply to message #228904] Wed, 21 March 2007 10:22 Go to previous messageGo to next message
> Best Kirill.
>>>> =true).
>>>> allinone.
>>>> Jason
>>> implemented.
>>> 2 - Bug submited.
>> <servlet-mapping>
>> </servlet-mapping>
>> To
>> <servlet-mapping>
>> </servlet-mapping>
>> Jason
I am using IE6 and I did not get this error. Where did you make the
change? BTW did you try the bookmarks with the webviewer? I also
logged a bug for this yesterday.
Jason
Re: Several questions after two weeks of development [message #229324 is a reply to message #228946] Thu, 22 March 2007 03:05 Go to previous messageGo to next message
I have changed it in
org.eclipse.birt.report.viewer_2.2.0.v20070208\birt\WEB-INF\ web.xml
I tried the bookmarks every where it possible. Look like
"javascript:catchBookmark" is not recognized.
news:etrf2e$mh0$1@utils.eclipse.org...
>> error: "line 1, char 1, code 0 Erorr:Object expected" )
>> Best Kirill.
>>>>> bookmark
>>>>> design->preview
>>>>> __overwrite
>>>>> =true).
>>>>> allinone.
>>>>> Jason
>>>> implemented.
>>>> 2 - Bug submited.
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> To
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> Jason
> change? BTW did you try the bookmarks with the webviewer? I also logged
> Jason
Re: Several questions after two weeks of development [message #229583 is a reply to message #229324] Thu, 22 March 2007 12:58 Go to previous message
>>> Best Kirill.
>>>>>> bookmark
>>>>>> design->preview
>>>>>> __overwrite
>>>>>> =true).
>>>>>> allinone.
>>>>>> Jason
>>>>> implemented.
>>>>> 2 - Bug submited.
>>>> <servlet-mapping>
>>>> </servlet-mapping>
>>>> To
>>>> <servlet-mapping>
>>>> </servlet-mapping>
>>>> Jason
>> Jason
If you use the internal browser this fails? When you preview do you use
an external browser? Have you tried this in the deployed version of BIRT?
Jason
Previous Topic:Viewer Integration - URL problems..
Next Topic:access to dataset before it is used by a report element
Current Time: Mon Nov 10 12:05:05 EST 2025
Powered by FUDForum. Page generated in 0.05098 seconds
