Stop Tomcat from the Servers tab [message #228023] |
Thu, 19 February 2009 04:49  |
Hi all,
Lately, that square red button that allows you to stop Tomcat in the
Servers tab has become unusable.
Before, when Tomcat didn't stop properly the first time I pushed the
button in question, I could always push it another time to force a stop.
But lately, when I press the button the first time, it shades and doesn't
allow another press, so if it's the case that Tomcat does not stop, I've
to force it from the task manager.
I'm using Tomcat 5.5 and Ganymede.
Thanks in advance and sorry for my English.
Re: Stop Tomcat from the Servers tab [message #228034 is a reply to message #228023] |
Thu, 19 February 2009 09:02   |
manuf wrote:
> Hi all,
> doesn't allow another press, so if it's the case that Tomcat does not
> stop, I've to force it from the task manager.
If you switch to the Debug perspective or open the Debug view, what does
the Debug view show for the Java Tomcat process. It is terminated or
still running?
Larry
Re: Stop Tomcat from the Servers tab [message #228057 is a reply to message #228049] |
Thu, 19 February 2009 12:09  |
Larry Isaacs wrote:
> The other process is the one that tells Tomcat to shutdown. Tomcat is
> getting the message to shutdown.
Understood.
> However, be aware that Tomcat will
> wait forever for webapps to fully clean up. Especially terminating any
> non-daemon threads the webapp creates.
Ok. This one I alredy knew because the application I'm working on has
never terminated properly (at least since I'm here). My curiosity is out
of the fact that, in the past, I could push the stop button a second time,
while now it appears disabled after the first time.
> To avoid this behavior you have to fix the
> webapp. You are welcome to run the server in Debug mode and see what
> threads remain after Tomcat is requested to shutdown. Unfortunately,
> finding and fixing the actual cause can be difficult.
:-) And shame on us for not having done it before, but the time margins
are always so small...
Thanks again (did I apologize for my English alredy?)
FUDForum. Page generated in 0.05463 seconds
