Home » Language IDEs » C / C++ IDE (CDT) » Importing projects + svn + parallel folders
Importing projects + svn + parallel folders [message #227942] Fri, 12 December 2008 11:41 Go to next message
Hi there,
I am looking for some help concerning project importing from svn
repositories and creating eclipse projects. Maybe someone can give me a
hint about how to do it:
I have 3 folders:
base_1/src/applic
base_2/src/applic
eclipse_workspace/other_stuff
What I want to do:
- import a svn project from a repository to applic (base_1/src/applic)
- import the same project to the other applic (base_2/src/applic)
- have both projects appear in eclipse with different project names
- my eclipse workspace cannot be under base_x nor can I influence the
folder names
This is what I want to see in eclipse:
eclipse_proj1 -> base_1/src/applic (@svn rep)
eclipse_proj2 -> base_2/src/applic (@svn rep)
The svn import tool only lets me import to my eclipse workspace and the
eclipse project name of the import is always identical to the folder name
(applic). Having two svn projects both point to folders of the same name
but at a different location seems impossible. Renaming a svn project is
also not possible.
A general hint at what to look at would already be helpful. Maybe some
simple edits in eclipse via GUI? Maybe ask the svn import tool devs? Maybe
write scripts to edit the eclipse metadata files or even the svn files?
My thanks in advance!
Re: Importing projects + svn + parallel folders [message #227995 is a reply to message #227942] Mon, 15 December 2008 04:23 Go to previous message
I would suggest the following:
1) Create a new C/C++ project with the project wizard. Call the new
project base_1. Unselect the option "Use default location" and choose a
folder for your source files *outside* of the exlipse workspace (this
option appears in the project wizard page where to choose the project
name). Choose the type of project (Makefile or managed project).
2) Repeat step 1 for project base_2
3) Select project base_1 in the project explorer or navigator. Right click
with your mouse and choose "Import". Choose as project type: SVN =>
Projects from SVN. Import the sources to your new projects.
I don't if this project type exists in your installation but this works
for CVS and perhaps the SVN-Plugin provides something similar.
Axel
> Hi there,
> I have 3 folders:
> base_1/src/applic
> base_2/src/applic
> What I want to do:
> folder names
> also not possible.
Previous Topic:How to reduce message on build console ?
Next Topic:Search in Selected Resources ?
Current Time: Sat Oct 11 22:48:07 EDT 2025
Powered by FUDForum. Page generated in 0.05884 seconds
