classpath trouble with my .jar [message #227595] |
Wed, 15 August 2007 17:07  |
Originally posted by: afrancoc2000.hotmail.com
I'm new at eclipse and I'm trying to create a .jar file that needs two
other different .jars to work well, jbcl.jar for borland layouts igot from
jBuilder, and mysqlConector.jar, for comunication with a data base in
mySql.
I have JDK 1.6 and i'm working at a 6.0 compliance level, I usually
execute my jars directly from windows, but with eclipse they don't work, I
have my java build path configured, but it seems like it doesn't go to the
manifest, my system classpath doesn't seem to work either, when I try
executing the jar from the console.
I do it like this:
java -cp "C:\Borland\JBuilder2005\lib\jbcl.jar" "C:\Archivos de
programa\Java\mysqlConnector\mysqlConnector.jar" -jar admin.jar
and when I try to modify the manifest directly there is a problem and
eclipse tells me that it couldn't generate the jar file because the
manifest is not sincroniced with the application.
I change my manifest like this:
Manifest-Version: 1.0
Main-Class: main.Main
Class-Path: "C:\Borland\JBuilder2005\lib\jbcl.jar" "C:\Archivos de
Can any body help me with this? I'm kind of lost. :(
Re: classpath trouble with my .jar [message #227672 is a reply to message #227595] |
Wed, 15 August 2007 22:11   |
Ana wrote:
> from jBuilder, and mysqlConector.jar, for comunication with a data base
> in mySql.
> I have my java build path configured, but it seems like it doesn't go to
> the manifest, my system classpath doesn't seem to work either, when I
> try executing the jar from the console.
> I do it like this:
> Thanks
You want both jbcl.jar and mysqlConnector.jar on the classpath, right?
Try
java -cp "c:\...\jbcl.jar;c:\...\mysqlConnector.jar;admin.jar" main.Main
and see if that works. Note that I put the program jar file in the
classpath, and that class path entries are separated by semicolons.
(Fill in the ellipsis, of course; I just put ... because I'm lazy.)
/Paul
Re: classpath trouble with my .jar [message #228136 is a reply to message #228100] |
Fri, 17 August 2007 20:24  |
Hi guys,
I know now what was wrong, I'm using an absolute path in the class-path at
the manifest and it has to be a relative one, so it never finds the jars
it needs.
ChuckBing at the java forums find it out!!
Thank you all you've been great,
Ana
FUDForum. Page generated in 0.65049 seconds
