API for validators [message #227537] |
Wed, 04 February 2009 14:20  |
It appears there is no public API for manipulating the state of validators
on a project. For example, disabling the build/manual setting or
adding/removing filters.
Using the changing internal API's is not a good option, because it means
being tied to specific versions of WTP where that internal API has not
changed.
Another option is to use the Eclipse preferences to manipulate the
validation preferences directly. This is a better option, because the
persisted values in the preferences would need to maintain the same
structure between WTP releases.
Both options, using the internal API or the preferences directly, aren't
good options, but the preference option seems to be "less" bad. Does
anybody have any other ideas/suggestions?
Nadeem
Re: API for validators [message #227545 is a reply to message #227544] |
Thu, 05 February 2009 13:05  |
Thanks for the reply.
The good news is that I've found a provisional API that provides some of
the functionality I need (org.eclipse.wst.validation.ValidationFramework).
I'm still trying it out to see if it provides what's needed or not.
After my testing and seeing what works and doesn't, I'll definitely open a
bug request as you mentioned.
- Nadeem
David Carver wrote:
> I recommend Openning a bug request for internal API to be made as Public
> API where needed.
> One thing in WTP we do not do is make enough items public API. In fact
> we technically should not be calling each others internal API between
> plugins. If we need functionality between our plugins, we should have
> public API. Internals should remain internal to the plugin.
> It's one of the reasons that the release train has a requirement for
> plugins on that train not to use internal API from other plugins.
> Dave
>> validators on a project. For example, disabling the build/manual
>> setting or adding/removing filters.
>> changed.
>> Thanks,
>> Nadeem
FUDForum. Page generated in 0.07805 seconds
