Home » Eclipse Projects » GEF » Delete action/button is dissabled
Delete action/button is dissabled [message #227270] Fri, 01 December 2006 06:20 Go to next message
Originally posted by: vikas.khengare.unnat-e.com
Hi friends,
I have put following code in "MultiPageEditorContributor", This is showing
me undo & redo functionality clear.
But for delete action "Delete" button icon is always disabled and not
performing any thing.
It is not enabling even single time.
1) Do I need to handle some thing for delete in "Command" where I have
handled for Undo & Redo?
2) Am I missing something in coding? what?
3) Do I need to do something with ActionRegistry / getActionRegistry?
public void contributeToToolBar(IToolBarManager manager) {
manager.add(getActionRegistry().getAction(ActionFactory.UNDO .getId()));
manager.add(getActionRegistry().getAction(ActionFactory.REDO .getId()));
manager.add(new Separator());
manager.add(getActionRegistry().getAction(ActionFactory.DELE TE.getId()));
protected void buildActions() {
addRetargetAction(new UndoRetargetAction());
addRetargetAction(new RedoRetargetAction());
addRetargetAction(new DeleteRetargetAction());
With best regards
From
Vikas R. Khengare
Re: Delete action/button is dissabled [message #227339 is a reply to message #227270] Sun, 03 December 2006 21:15 Go to previous messageGo to next message
Hi Vikas,
It seems to me that you're trying to add GEF's retarget actions to a
Multipage editor, which is not a GEF application. There is no need to add
GEF's actions to it... you can simply add to tool bar actions defined for
text editors already. GEF's actions won't work there correctly anyway.
I've tried to do the following in setActivePage(IEditorPart) method inside
if (actionBars != null) block:
actionBars.getToolBarManager().add(getAction(editor,ITextEdi torActionConstants.UNDO));
actionBars.getToolBarManager().add(getAction(editor,ITextEdi torActionConstants.REDO));
actionBars.getToolBarManager().add(getAction(editor,ITextEdi torActionConstants.DELETE));
This is merely an example, I'm not 100% sure that that is the right place
to put those 3 lines in. Try posting this question on Eclipse PDE
newsgroup.
Hope this helps.
Alex
Re: Delete action/button is dissabled [message #227367 is a reply to message #227339] Mon, 04 December 2006 04:10 Go to previous messageGo to next message
Hi friends
Thanks alex for your reply.
I have enabled delete button on right click by following code
public void buildContextMenu(IMenuManager menu)
action = getActionRegistry().getAction(ActionFactory.DELETE.getId());
action.setEnabled(true);
if (null != action && action.isEnabled())
menu.appendToGroup(GEFActionConstants.GROUP_EDIT, action);
But still now also it is not performing any action. It is not creating
command.
It is not calling "getCommand()" even.
In Edit Part; I worte ...
protected void createEditPolicies() {
installEditPolicy(EditPolicy.COMPONENT_ROLE, new RectangleEditPolicy());
In "RectangleEditPolicy" class I wrote
class RectangleEditPolicy extends ComponentEditPolicy{
public Command getCommand(Request request) {
System.out.println(request.getType());
return super.getCommand(request);
But this is not calling getCommand() method.
Can Someone help me in this scenario?
Note : 1] This is MultiPageEditor
2] Where my main editor class extends GraphicalEditor
With best regards
From
Vikas R. Khengare
"Alex Boyko" <aboyko@ca.ibm.com> wrote in message
news:179dd5c5ce95617b1d2633657335bcc9$1@www.eclipse.org...
> Hi Vikas,
ts.UNDO));
ts.REDO));
ts.DELETE));
> newsgroup.
> Hope this helps.
> Cheers,
> Alex
Re: Delete action/button is dissabled [message #227391 is a reply to message #227270] Mon, 04 December 2006 21:23 Go to previous messageGo to next message
Hi Vikas,
Your retarget delete action does not have a handler - the actual
DeleteAction that will create and execute the command. So your retarget
delete action is not doing anything at the moment.
Try doing the following in your action bar contrubutor class, where you
contribute actions to tool bars and menus:
protected void declareGlobalActionKeys() {
addGlobalActionKey(ActionFactory.DELETE.getId())
You're adding Undo and Redo global key handlers somewhere right now,
either in the action bar contributor or the editor's class in init()
method. Insert the global key handler for delete in the same place. (This
is how it's done in the Logic example editor)
Hope this helps.
Alex
Re: Delete action/button is dissabled [message #227398 is a reply to message #227391] Tue, 05 December 2006 00:23 Go to previous messageGo to next message
Hi Alex & other friends
I have done that already ... in class "MultiPageEditorContributor extends
ActionBarContributor"
// same for Undo & Redo
addGlobalActionKey(ActionFactory.DELETE.getId());
addGlobalActionKey(ActionFactory.UNDO.getId());
addGlobalActionKey(ActionFactory.REDO.getId());
As I told you I wrote ...... I wrote every thing ....... 1] Context menu 2]
Installed EditPolicy in edit Part 3] Actual EditPolicy class
command.
{ public Command getCommand(Request request) {
What's the wrong ?
With best regards
From
Vikas R. Khengare
news:2deda39a1ce6b9e0fb084e79e9eff68f$1@www.eclipse.org...
> Hi Vikas,
> Hope this helps.
> Cheers,
> Alex
Re: Delete action/button is dissabled [message #227428 is a reply to message #227398] Tue, 05 December 2006 04:34 Go to previous message
hi alex / other friends,
I got the solution ....... I haven't override init() methods of
GraphicalEditor class.
Hope so this was missing ....... right alex?
With best regards
From
Vikas R. Khengare
"Vikas" <vikas.khengare@unnat-e.com> wrote in message
news:el2vob$m41$1@utils.eclipse.org...
2]
> command.
> What's the wrong ?
> With best regards
> From
> Vikas R. Khengare
> > Hi Vikas,
(This
> > Hope this helps.
> > Cheers,
> > Alex
Previous Topic:Where to persist a model's graphical information?
Next Topic:Problem in Shapes example
Current Time: Sun Nov 02 18:53:39 EST 2025
Powered by FUDForum. Page generated in 0.04028 seconds
