Home » Language IDEs » ServerTools (WTP) » Get Project Properties in ContentAssistProcessor
Get Project Properties in ContentAssistProcessor [message #225808] Tue, 30 December 2008 15:27 Go to next message
Hi there,
I implemented a little plugin to extend content assistance and
validation for HTML files. Everything works fine so far: I extended
StructuredTextViewerConfigurationHTML and returned my own
ContentAssistProcessor.
However, the possible proposals are dependent on some project specific
properties (at least in some cases). I understand how to store these
properties on the project resource, but I don't know how to get to the
IProject resource from my ContentAssistProcessor. In
IContentAssistProcessor.computeCompletionProposals there is a
ITextViewer object and in my
StructuredTextViewerConfiguration.getContentAssistProcessors a
ISourceViewer object as parameter, but I don't see a way to get to the
project resource from there. Can anybody help?
Thanks in advance and a happy 2009,
Dominik
Re: Get Project Properties in ContentAssistProcessor [message #225855 is a reply to message #225808] Fri, 02 January 2009 19:05 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Dominik Raymann wrote:
> Hi there,
I suspect you need to access it through the bundle getWorkspace()
method, and then get then check the appropriate project. You might also
be able to get the project from the IDocument for the particular file or
the EditorPart.
Dave
Re: Get Project Properties in ContentAssistProcessor [message #227119 is a reply to message #225855] Thu, 22 January 2009 14:07 Go to previous messageGo to next message
>> Hi there,
> the EditorPart.
> Dave
Thanks for your answer. However, I don't see how I can access my bundle
from my ContentAssistProcessor (or my validator). Do I have to pass a
reference to it somehow? Could you give an example?
I also don't know how to get to the project from the IDocument as a
starting point. Does anybody have an example? I think this should be a
quite common problem, shouldn't it?
Dominik
Re: Get Project Properties in ContentAssistProcessor [message #228358 is a reply to message #227119] Wed, 25 February 2009 17:32 Go to previous messageGo to next message
Just in case anybody has found this thread while googling for an answer
to a question similar to mine:
I found a way to get the actual file of a IDocument (if there is an
associated WST model). I can't remember where I found the code, I think
it's from a Spring Plugin. You can easily get the project afterwards by
calling the getProject() method of the file afterwards. I don't know
whether it is the best way, but it seems to work. So here we go:
public static final IFile getFile(IDocument document) {
IFile resource = null;
String baselocation = null;
if (document != null) {
IStructuredModel model = null;
try {
model = org.eclipse.wst.sse.core.StructuredModelManager
..getModelManager().getExistingModelForRead(document);
if (model != null) {
baselocation = model.getBaseLocation();
} finally {
model.releaseFromRead();
if (baselocation != null) {
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IPath filePath = new Path(baselocation);
if (filePath.segmentCount() > 0) {
resource = root.getFile(filePath);
return resource;
>>> Hi there,
>> also be able to get the project from the IDocument for the particular
>> file or the EditorPart.
>> Dave
> Dominik
Re: Get Project Properties in ContentAssistProcessor [message #228366 is a reply to message #228358] Wed, 25 February 2009 20:52 Go to previous message
Just don't forget to check whether that file exists. The base
location of the model will be the file system location if you've
opened a file from outside of the workspace.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Previous Topic:Missing Dependent Project on Java EE Module Dependencies Page
Next Topic:Re: Weblogic 10 integration issue in Eclipse 3.4.1
Current Time: Thu Jul 24 21:45:13 EDT 2025
Powered by FUDForum. Page generated in 0.27747 seconds
