Home » Language IDEs » Java Development Tools (JDT) » Searching for implementors of an interface
Searching for implementors of an interface [message #226911] Fri, 31 March 2006 08:50 Go to next message
Suppose I have the following types in a workspace:
interface A
interface B extends A
class MyA implements A
abstract class MyB implements B
class MyC extends MyB
How could I construct a JDT search to find all concrete classes that
implement the interface A? (in the example I would expect results to include
MyC and MyA)
I have tried using a pattern like:
SearchPattern superPattern = SearchPattern.createPattern(aType,
IJavaSearchConstants.IMPLEMENTORS);
Where aType is an IType for interface A.
I was expecting to see that include the abstract classes and interface B...
but I get no results!?
Any tips appreciated...
- Chris
Re: Searching for implementors of an interface [message #226925 is a reply to message #226911] Fri, 31 March 2006 09:33 Go to previous messageGo to next message
After a bit more testing it seemed the search only works with interfaces?
If the aType is an abstract class it does not return classes that "extend"
that class. But the documentation for the IMPLEMENTORS flag states that:
"The search result is a type that implements an interface or extends a
class. Used in conjunction with either TYPE or CLASS or INTERFACE, it will
respectively search for any type implementing/extending a type, or rather
exclusively search for classes implementing/extending the type, or
interfaces extending the type."
Which is what confused me ... it seems I have a choice of TYPE, CLASS or
INTERFACE? I thought it might deduce CLASS or INTERFACE from the IType I
passed in, and only do a TYPE search if I specify that.
- Chris
Re: Searching for implementors of an interface [message #226931 is a reply to message #226925] Fri, 31 March 2006 09:45 Go to previous messageGo to next message
While I am on the subject...
Has anyone noticed the JavaDoc for
SearchPattern.createPattern(IJavaElement[], .. etc) methods contains HTML
unordered lists that do not match up. I am looking at the 3.1 online help.
The indentation goes all weird and the @return comments end up in the
wrong place.
Looking at the source code it seems it is opening a new UL element when
they mean to be closing the last one, i.e. the '/' character is missing.
- Chris
Re: Searching for implementors of an interface [message #227027 is a reply to message #226925] Mon, 03 April 2006 10:58 Go to previous messageGo to next message
> "extend" that class. But the documentation for the IMPLEMENTORS flag
> states that:
> will respectively search for any type implementing/extending a type, or
> rather exclusively search for classes implementing/extending the type,
> or interfaces extending the type."
> - Chris
It's a known problem and we're also confused on the subject :-(
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=124645.
We'll try to make it clear for 3.2 RC1...
Re: Searching for implementors of an interface [message #227033 is a reply to message #226931] Mon, 03 April 2006 11:13 Go to previous message
> HTML unordered lists that do not match up. I am looking at the 3.1
> online help.
> wrong place.
> - Chris
That's true, I'll fix it.
Thanks for pointing this out.
Previous Topic:managing source directories from a plugin
Next Topic:Get default value of field without using AST
Current Time: Fri Nov 07 04:02:28 EST 2025
Powered by FUDForum. Page generated in 0.03924 seconds
