Home » Language IDEs » ServerTools (WTP) » Re: Setting up a new dynamic web project
Re: Setting up a new dynamic web project [message #226812] Fri, 16 January 2009 11:42 Go to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
Copying to eclipse.webtools.
Mila Mitra wrote:
> Hello,
> I am a newbie to Eclipse.
> I have been handed two projects as directory structures, a web project
> with jsp, html, and js files. Also a separate project which has many
> Java packages and servlets.
> I am able to import the Java web structure to an Eclipse Java project,
> and the webfiles to a dynamic web project/WebContent area.
> However, the JSP files in the dynamic web project use the Java classes
> (page imports).
> My question is how to make this work?
> 1. Keep these as separate projects (1 dynamic web project and one Java
> project). In that case how do the import statements work from another
> project?
> OR
> 2. Put the Java packages also in the Java:src area of the dynamic web
> project? Where do I place the Servlets?
> This is how it currently looks:
> - TestJava (java project)
> /src
> com.app.techassist
> TechAssistApp.java
> - wsdev (dynamic web project)
> /WebContent
> main.jsp
> main.jsp has <%@ page import="com.app.techassist.TechAssistApp" %>
> How can I make main.jsp see the Java package? Also, how would I build
> this whole thing?
> I would appreciate any help.
> Thanks, Mila
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: Setting up a new dynamic web project [message #226818 is a reply to message #226812] Fri, 16 January 2009 12:23 Go to previous message
> Mila Mitra wrote:
>> Hello,
>> (page imports).
>> project?
Open the Properties dialog for the web project and go to the Java EE
Module Dependencies page. Add a check for the Java project and click
OK. When the web project is published to a server or exported as a WAR
or as part of an EAR file, a jar will be created from the Java project
and included in the Web application's WEB-INF/lib.
>> OR
The artifacts built from content placed under Java:src of the web
project will be included in the Web application's WEB-INF/classes. The
default dynamic web project will build the Java content to the
"build/classes" folder of the project. When the web project is
published to a server or exported, the "build/classes" content gets
copied to or included in "WEB-INF/classes".
>> /src
>> com.app.techassist
>> TechAssistApp.java
>> /WebContent
>> main.jsp
Either approach above would fix this.
>> this whole thing?
As mentioned above, "assembly" occurs when the project is published to a
server or is exported as a WAR, or as part of an EAR.
Larry
>> Thanks, Mila
Previous Topic:Web Services Explorer for UDDI v3
Next Topic:Creating a web project around an existing file structure?
Current Time: Wed Jul 23 21:41:00 EDT 2025
Powered by FUDForum. Page generated in 0.25928 seconds
