Home » Language IDEs » Java Development Tools (JDT) » Comman line invocation of Java application
Comman line invocation of Java application [message #226642] Mon, 27 March 2006 21:44 Go to next message
Originally posted by: chandrac.kestral.com.au
Folks,
Suppose I have developed within Eclipse a simple Java application with a
main method that requires input from standard input and that outputs to
standard output. It has been run successfully as a Java application
from within Eclipse.
Without copying individual files to some other directory, and keeping
intact the existing project directory structure in my workspace, I want
to run the application outside of Eclipse with a command line invocation
to java, passing the appropriate command line arguments.
Is there any way I can extract this invocation from within Eclipse, to
use on a command line window like a bash shell in Linux or a DOS window
in Windows?
If I cannot extract the invocation from within Eclipse, how may I
assemble it otherwise?
Thanks.
Chandra
Re: Comman line invocation of Java application [message #226648 is a reply to message #226642] Mon, 27 March 2006 23:21 Go to previous messageGo to next message
Originally posted by: newsgroups.pellaton.li
The only place I know where the complete command line of the invocation
is shown is in the debugger.
- set some breakpoint in your app
- run it using the debugger
- in the 'Debug' view, right click on the thread
- select 'Properties'
- this should give you the command that was used to invoke the app
HTH,
Michael Pellaton
Re: Comman line invocation of Java application [message #226652 is a reply to message #226648] Tue, 28 March 2006 00:50 Go to previous messageGo to next message
Thank you. That worked.
I needed to modify the extracted command line as follows:
1. Change the executable from javaw to java for Windows;
2. Remove the following options from the command line:
-Xdebug -Xnoagent
-Xrunjdwp:transport=dt_socket,suspend=y,address=localhost:16 80
The resulting command then ran just like any Java application invoked
from the command line.
Chandra
Michael Pellaton wrote:
> Hello,
> HTH,
> Michael Pellaton
Re: Comman line invocation of Java application [message #226662 is a reply to message #226652] Tue, 28 March 2006 03:11 Go to previous messageGo to next message
> -Xdebug -Xnoagent
There's something else you can do: create a Jar with all the classes in
them and a manifest that contains a proper Class-Path and Main-Class.
You then still have to provide JVM and other command line arguments but
you can invoke it with
java -jar -X... your.jar arg1 arg2
Kind regards
robert
Re: Comman line invocation of Java application [message #226755 is a reply to message #226662] Tue, 28 March 2006 22:24 Go to previous message
Robert,
I exported the project as a JAR (ensuring that the package and relevant
class were recognized) and invoked the program with
java -jar <full_path_to_.jar_file>
and it worked perfectly.
Thank you.
Chandra
29 Mar 06
> Kind regards
> robert
Previous Topic:How can I turn off the source lookup in the debug framework
Next Topic:Putting jars from jared plugins on classpath
Current Time: Fri Nov 07 05:23:07 EST 2025
Powered by FUDForum. Page generated in 0.04903 seconds
