Home » Language IDEs » ServerTools (WTP) » Adding an item to Design View's context menu via extension point?
Adding an item to Design View's context menu via extension point? [message #225901] Mon, 05 January 2009 10:12 Go to next message
Hello!
I'd like to ask how can I contribute an action to a XML Schema design view
context menu via extension point.
There is an extension point called
org.eclipse.wst.xsd.core.xsdsource.source.
EditorContext for dealing with source view context menu, but is there any
such mechanism for design view?
Blazej Kroll
Re: Adding an item to Design View's context menu via extension point? [message #225909 is a reply to message #225901] Mon, 05 January 2009 10:53 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Take a look at the following Wiki page, it should help:
http://wiki.eclipse.org/Table_of_WTP_IDs
Dave
Blazej Kroll wrote:
> Hello!
> view context menu via extension point.
> org.eclipse.wst.xsd.core.xsdsource.source. EditorContext for dealing
> with source view context menu, but is there any such mechanism for
> design view?
> Regards,
> Blazej Kroll
Re: Adding an item to Design View's context menu via extension point? [message #225948 is a reply to message #225909] Mon, 05 January 2009 16:47 Go to previous messageGo to next message
> Dave
> Blazej Kroll wrote:
>> Hello!
>> design view?
>> Regards,
>> Blazej Kroll
We will move over to the new menu extensions as part of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258350
In the meantime, you can use the popupMenus extension point with
'additions' as your menubarPath.
Re: Adding an item to Design View's context menu via extension point? [message #226122 is a reply to message #225948] Wed, 07 January 2009 08:40 Go to previous messageGo to next message
Thank you very much for the posts, I managed to create such a context menu
contribution in XML Schema design view page using:
org.eclipse.ui.menus
extension point and locationURI:
popup:org.eclipse.wst.xsd.ui.popup.graph?after=additions
However, I can not find a bug with a patch that introduced it. Can you
point me to one? For now, I checked and it works in 3.0.3, but I'd like to
see it working in WTP 2.0.x. (if it is possible of course).
Błażej Kroll
Re: Adding an item to Design View's context menu via extension point? [message #226282 is a reply to message #226122] Fri, 09 January 2009 01:19 Go to previous message
The org.eclipse.ui.menus extension point was added in Eclipse 3.3, and
became more stable in eclipse 3.4. So it SHOULD work with WTP 2.0.x
but might not.
Dave
Blazej Kroll wrote:
> Hello,
> menu contribution in XML Schema design view page using:
> org.eclipse.ui.menus extension point and locationURI:
> to see it working in WTP 2.0.x. (if it is possible of course).
> Best regards,
> Błażej Kroll
Previous Topic:Format javascript source code before save
Next Topic:SSE editor content
Current Time: Wed Jul 23 05:37:36 EDT 2025
Powered by FUDForum. Page generated in 0.05884 seconds
