Home » Archived » BIRT » Report on a Java Application (not RCP)
Report on a Java Application (not RCP) [message #225622] Thu, 15 March 2007 15:41 Go to next message
Originally posted by: henriquemagalhaes.gmail.com
Hi...
I have a report generator working in a RCP application. For it I put the
following plug-ins in the Mainfest Dependencies tab:
org.eclipse.birt.report.engine
org.eclipse.birt.report.engine.emitter.html
Is it possible to run a report from a Java Application (that does not have
a Manifest file)? How can I do it?
Thanks...
Re: Report on a Java Application (not RCP) [message #225663 is a reply to message #225622] Thu, 15 March 2007 16:39 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Henrique wrote:
> Hi...
> have a Manifest file)? How can I do it?
> Thanks...
If you download the runtime there is an example of a stand alone Java
app that runs birt reports. It still uses the plugins but the app
itself is not a plugin. I am not certain if this is what you want.
Jason
Re: Report on a Java Application (not RCP) [message #225695 is a reply to message #225663] Thu, 15 March 2007 17:34 Go to previous messageGo to next message
In my RCP application I did not use the setEngineHome Method, like in the
BIRT RCP Engine example. But in the Simple Execute example it is used, and
set to a file system path. I think this is my problem (because I changed
my RCP code to use in a Java Application).
I did not understand if I need to deploy the Engine for my Applications
user alone and set the Engine home (config.setEngineHome method) or if it
is possible to "deploy" the Engine inside my Application. In that case how
can I tell my application where to find the Engine? In other words, I did
not understand how to use the plugins in the Java application like in the
RCP Application.
Jason Weathersby wrote:
> Henrique wrote:
>> Hi...
>> Thanks...
> Jason
Re: Report on a Java Application (not RCP) [message #225911 is a reply to message #225695] Fri, 16 March 2007 11:38 Go to previous messageGo to next message
> the BIRT RCP Engine example. But in the Simple Execute example it is
> used, and set to a file system path. I think this is my problem (because
> I changed my RCP code to use in a Java Application).
> it is possible to "deploy" the Engine inside my Application. In that
> case how can I tell my application where to find the Engine? In other
> words, I did not understand how to use the plugins in the Java
> application like in the RCP Application.
>> Henrique wrote:
>>> Hi...
>>> the following plug-ins in the Mainfest Dependencies tab:
>>> Thanks...
>> Jason
If you look at the stand alone example it has to set a BIRT_HOME where
it looks for a plugins directory. This is different than the RCP
example. You will also need to add the appropriate libs to your classpath.
Jason
Re: Report on a Java Application (not RCP) [message #226066 is a reply to message #225911] Fri, 16 March 2007 16:11 Go to previous messageGo to next message
Ok. Thank you...
Other question: I'm getting null in this line:
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
Can you tell me why?
Henrique
>>> Henrique wrote:
>>>> Hi...
>>>> Thanks...
>>> Jason
> Jason
Re: Report on a Java Application (not RCP) [message #227988 is a reply to message #226066] Mon, 19 March 2007 11:30 Go to previous message
Henrique wrote:
> Ok. Thank you...
> Henrique
>>> (because I changed my RCP code to use in a Java Application).
>>> Applications user alone and set the Engine home (config.setEngineHome
>>> method) or if it is possible to "deploy" the Engine inside my
>>> Application. In that case how can I tell my application where to find
>>> the Engine? In other words, I did not understand how to use the
>>> plugins in the Java application like in the RCP Application.
>>>> Henrique wrote:
>>>>> Hi...
>>>>> put the following plug-ins in the Mainfest Dependencies tab:
>>>>> not have a Manifest file)? How can I do it?
>>>>> Thanks...
>>>> Java app that runs birt reports. It still uses the plugins but the
>>>> app itself is not a plugin. I am not certain if this is what you want.
>>>> Jason
>> classpath.
>> Jason
This usually happens when BIRT_HOME is set incorrectly. The BIRT
Plugins can not be found.
Jason
Previous Topic:variable set in nested table is one row back
Next Topic:SQLException: Missing IN or OUT parameter
Current Time: Mon Jul 21 00:23:47 EDT 2025
Powered by FUDForum. Page generated in 0.04733 seconds
