Home » Archived » BIRT » Getting charts to appear...
Getting charts to appear... [message #22602] Thu, 24 March 2005 15:25 Go to next message
Originally posted by: mbatchelor.no_s_p_a_m.pentaho.com
Hey all,
I've bound a simple bar chart to my dataset using the properties. I've then
specified the x-axis and y-axis values using row["whatever"].
However, whenever I preview, regardless of whether I'm previewing as html or
in a PDF, no chart ever appears.
Anyone have any hints?
Marc
Re: Getting charts to appear... [message #22731 is a reply to message #22602] Thu, 24 March 2005 20:56 Go to previous messageGo to next message
Hi Marc,
This is a known issue. We are working on correcting the problem and should
have a fix soon.
On a related note, are you using the latest source sync'd from CVS?
Rohit Colaço
ECE Project Lead
Hey all,
or
Marc
Re: Getting charts to appear... [message #23385 is a reply to message #22602] Mon, 28 March 2005 17:15 Go to previous message
Hi Marc,
I sync'd the source with CVS earlier this morning and charts appear in the
output correctly. Here's the sequence of steps that I followed:
A] Sync'd and updated source for all BIRT plug-ins
B] Ran build.xml from the viewer/ plug-in which updates the viewer web-app
with all required BIRT libraries in the expected folder structure
C] Re-built the chart.reportitem plug-in via a Project => Clean (because
its build.xml does a selective build for runtime components causing only a
partial compilation)
D] Ran the workbench
E] Created a new chart; specified a dataset; bound its X series and Y
series to appropriate dataset columns; viewed the output in HTML and it
worked
There is a pending issue with viewing charts in PDF that is being
addressed but HTML output should work.
Rohit Colaço
ECE Project Lead
Hey all,
or
Marc
Previous Topic:Version in CVS - Plugin creation problems
Next Topic:BRIT_VIEWER_LOCALE ?
Current Time: Mon Nov 10 04:16:44 EST 2025
Powered by FUDForum. Page generated in 0.05077 seconds
