Home » Eclipse Projects » GEF » Moving a block container and its children NOT WORKING
Moving a block container and its children NOT WORKING [message #225620] Tue, 31 October 2006 20:05 Go to next message
Originally posted by: vinhtran2004-eclipsezone.yahoo.com
I have an GEF editor that draws a block container which has children in the box (boxes). I move the block container around and see the block container children move with it, but when I select a child box in block container, the selected and the other children are back to the original location. I believe the children locations don't update and I check it. My questions are:
How to get the x and y position when the parent box move?
Do I have to make the children x and y position relative to parent box?
Any suggestion? Thanks.
Vinh
Re: Moving a block container and its children NOT WORKING [message #225630 is a reply to message #225620] Wed, 01 November 2006 00:50 Go to previous messageGo to next message
VINH TRAN 写道:
> Vinh
Maybe there not a layout in block container box, if so, set it with a
layout manager.
If have layoutEditPolicy in editPart, can do
createChangeConstraintCommand in LayoutEditPolicy subclass, for example,
XYLayoutEditPolicy.
protected Command createChangeConstraintCommand(EditPart child,
Object constraint) {
Rectangle bounds = null;
if (constraint instanceof Rectangle) {
bounds = (Rectangle) constraint;
} else if (constraint instanceof Point) {
bounds = new Rectangle();
bounds.setLocation((Point) constraint);
this code answer question 1, if x, y location referred to child in the
question, if referred to parent self, so the code is in parent of parent
editpolicy.
when use layout, x, y of child are default ralative to parent figure.
Qinxian
Re: Moving a block container and its children NOT WORKING [message #225693 is a reply to message #225630] Wed, 01 November 2006 12:35 Go to previous messageGo to next message
Do you know any source that I can read to know more about layout and GEF stuffs. I got the Red book but it help just a little. Thanks.
Vinh
Re: Moving a block container and its children NOT WORKING [message #225701 is a reply to message #225693] Wed, 01 November 2006 12:36 Go to previous messageGo to next message
Hi Quinxian,
Thank for the help. I will check it.
Vinh
Re: Moving a block container and its children NOT WORKING [message #225757 is a reply to message #225701] Wed, 01 November 2006 18:17 Go to previous message
VINH TRAN 写道:
> Hi Quinxian,
> Vinh
DMI.
Try to find in eclipsewiki.
http://wiki.eclipse.org/index.php/Graphical_Editing_Framewor k
Seem that there is little of stuffs.
Qinxian
Previous Topic:UpdateListener.firePainting(Rectangle, Map) causes NullPointerException
Next Topic:connection figure antialiasing
Current Time: Fri Nov 07 03:49:25 EST 2025
Powered by FUDForum. Page generated in 0.04008 seconds
