Home » Newcomers » Newcomers » Differences Eclipse Classic <> Eclipse IDE?
Differences Eclipse Classic <> Eclipse IDE? [message #225727] Sat, 04 August 2007 20:20 Go to next message
Originally posted by: maths.jose.gmail.com
Absolutely new comer on Eclipse.
What're differences between Eclipse Classic & Eclipse IDE ?
( http://www.eclipse.org/downloads/ )
Which one I've to download?
Can I use JDK/JRE 6 for Eclipse ?
Re: Differences Eclipse Classic <> Eclipse IDE? [message #225737 is a reply to message #225727] Sat, 04 August 2007 22:26 Go to previous messageGo to next message
Hi MJ,
Eclipse Classic.
The choice of labels is confusing for new-comers.
Yes you can use JDK/JRE 6.
However, be careful if you intend to interface with programs such as
JBoss 4.x. These programs are compiled against JRE 5 and will create
serialization errors that are difficult to find if you use JRE 6.
Hope this helps.
Charlie
Re: Differences Eclipse Classic <> Eclipse IDE? [message #225753 is a reply to message #225727] Sat, 04 August 2007 22:58 Go to previous message
That depends on what you want to do with the tool. I think the
explanations on that page do a pretty good job of guiding you, but there
are also links to "Find out more..." under each package description.
Usually what a Java programmer wants is the Eclipse IDE for Java
Developers. Even if you eventually want more of the tools, you can
easily use the built-in Update Manager to download and install them.
Yes, Eclipse runs under Java 6 just fine.
Hope this helps,
Eric
Previous Topic:Eclipse 3.3 for 64 bits processor
Next Topic:how to report error like JDT does?
Current Time: Fri Oct 10 18:45:33 EDT 2025
Powered by FUDForum. Page generated in 0.11442 seconds
