Home » Eclipse Projects » Plugin Development Environment (PDE) » eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects)
| Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #21676 is a reply to message #21631] |
Fri, 12 September 2008 12:41    |
Eclipse User  |
Originally posted by: ekkehard.gentz-software.de
ekke schrieb:
> ekke schrieb:
>> Chris Aniszczyk schrieb:
>>> ekke wrote:
>>>> after refactoring-renaming some plug-in projects I noticed a
>>>> significant slow-down at
>>>> * start-up
>>>> * saving MANIFEST.MF
>>>> * saving built.properties
>>>> * opening / closing plug-in projects
>>>> saving .java
>>>> opening / closing non-plug-in projects
>>>> is as fast as before
>>>> starting with -clean doesnt help
>>> How big is your target platform in terms of plug-ins?
>> around 600 (RCP, Equinox, Riena, Easybeans, some from SpringSource)
>> I went back and restored eclipse app folder and complete workspace
>> from TimeMachine
>> ...all is fast as before
>> then again changed 5 plug-in names (because its no good idea to have
>> projects in workspace ending with .service on OSX ;-)
>> ...and its slow
>> really curious...
> additional info:
> opening build.properties
> removing /src
> saving
> needs 210 seconds ... only watching the colored wheel cursor
> and CPU activity is 100%
additional info:
Target Platform  - Load Target, Apply
....Resetting Target Platform needs 180 seconds
ekke
> ekke
>> ekke
>>> Cheers,
>>> ~ Chris
| Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #22571 is a reply to message #21676] |
Wed, 17 September 2008 04:30   |
Eclipse User  |
ekke schrieb:
>>>>> * start-up
>>>>> saving .java
>>> from TimeMachine
>>> ...and its slow
>>> really curious...
>> additional info:
>> removing /src
>> saving
> additional info:
> ekke
>> ekke
>>> ekke
>>>> Cheers,
>>>> ~ Chris
Chris,
finally I found out that the renaming of the projects wasn't the reason.
the slowdown was caused by Cycles and wrong package-uses
(see bugzilla 208011, bugzilla 246615) PDE detects in 3rdparty bundles.
all things caused by some bundles from easybeans where PDE detects
cycles and if my own bundles have dependencies via package-import then
sometime trouble starts.
I found some workarounds to minimize trouble loading some fake bundles
into workspace ;-)
in the meantime I know, if "resetting target platform" or "starting
eclipse - initialize java tooling - configuring plugin-dependencies"
takes a long time then I have to look thru my bundles in workpace to see
if there's a plug-in dependency to easybeans.core then I have to
workaround this.
so today I got my startup .... configuring plugin-dependencies from more
then 5 minutes to 1 second
I also from time to time get not only cycles - also wrong package-uses,
but I'm still working to make a small example reproduceable for bugzilla
  246615.
ekke
| Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580142 is a reply to message #21548] |
Fri, 12 September 2008 12:12   |
Eclipse User  |
>> * start-up
>> saving .java
I went back and restored eclipse app folder and complete workspace from
TimeMachine
....all is fast as before
....and its slow
really curious...
ekke
> Cheers,
> ~ Chris
| Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580168 is a reply to message #21587] |
Fri, 12 September 2008 12:25   |
Eclipse User  |
>>> * start-up
>>> saving .java
> TimeMachine
> ...and its slow
> really curious...
additional info:
removing /src
saving
ekke
> ekke
>> Cheers,
>> ~ Chris
| Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580192 is a reply to message #21631] |
Eclipse User  |
>>>> * start-up
>>>> saving .java
>> from TimeMachine
>> ...and its slow
>> really curious...
> additional info:
> removing /src
> saving
additional info:
ekke
> ekke
>> ekke
>>> Cheers,
>>> ~ Chris
| Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580662 is a reply to message #21676] |
Eclipse User  |
ekke schrieb:
>>>>> * start-up
>>>>> saving .java
>>> from TimeMachine
>>> ...and its slow
>>> really curious...
>> additional info:
>> removing /src
>> saving
> additional info:
> ekke
>> ekke
>>> ekke
>>>> Cheers,
>>>> ~ Chris
Chris,
into workspace ;-)
workaround this.
  246615.
ekke
 Current Time: Tue Nov 04 08:57:54 EST 2025
 Powered by  FUDForum. Page generated in 0.05819 seconds
