Home » Language IDEs » ServerTools (WTP) » Adding custom script support to JSP Editor
Adding custom script support to JSP Editor [message #225530] Sun, 21 December 2008 10:21 Go to next message
I've been looking to extend the WTP JSP editor to support a custom
scripting language located inside tags declared in a taglib.
A sample page looks like this :
========================= sample.jsp ==========================
<%@ taglib uri="/WEB-INF/lib/..." prefix="myprefix" %>
<%@ page import="..." %>
<myprefix:scene name="sample">
//Java code here
<myprefix:function name="fname" params="">
//custom language scripting
</prefix:function>
</prefix:function>
</myprefix:scene>
======================== /sample.jsp =========================
How to proceed to provide content-assist for the scripting inside the
<myprefix:function> element ?
Thanks.
Emmanuel.
Re: Adding custom script support to JSP Editor [message #225576 is a reply to message #225530] Mon, 22 December 2008 15:40 Go to previous messageGo to next message
> //Java code here
> </prefix:function>
> </prefix:function>
> </myprefix:scene>
Typically we've allowed content assist, and other features, to be
contributed according to the partition type at that location in the
document, but the JSP partitioner we use isn't written to vary the
partition type within custom tags. I assume this is with tags whose
content is identified as tagdependent? You should open a feature
request for allowing this, but how to consistently create the same
partition name when the taglib URI and prefix declaring the tag are
variable is a problem that would need to be solved.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Adding custom script support to JSP Editor [message #225584 is a reply to message #225576] Tue, 23 December 2008 04:58 Go to previous message
Thanks for your answer. I opened a feature request (#259550)
Previous Topic:SSL Connection timeout with Tomcat 5.5.x & 6.x started from Eclipse 3.4
Next Topic:Working with CSS Framework
Current Time: Wed Jul 23 06:45:21 EDT 2025
Powered by FUDForum. Page generated in 0.05932 seconds
