Home » Language IDEs » ServerTools (WTP) » XML Catalog Question
XML Catalog Question [message #225500] Sat, 20 December 2008 11:40 Go to next message
This post is in reference to
< http://dev.eclipse.org/newslists/news.eclipse.webtools/msg17 065.html>
where I was having problems entering an XML Catalog entry in which the
file resides in the local Maven repository on a Windows machine. The path
the local Maven repository included both spaces and a '.' character:
C:\Documents and Settings\username\.m2
It turned out that the solution was to map the above path to a drive:
subst Z: "C:\Documents and Settings\ username\.m2"
Once this mapping was in place it was possible to reference the jar file
location with no spaces or '.' character which worked correctly in the
dialog for entering an XML Catalog entry in Eclipse.
Re: XML Catalog Question [message #225515 is a reply to message #225500] Sat, 20 December 2008 20:50 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
This sounds like a bug needs to be opened, so that the URL is correctly
encoded so that spaces are converted to %20.
> path the local Maven repository included both spaces and a '.' character:
Re: XML Catalog Question [message #225522 is a reply to message #225515] Sun, 21 December 2008 06:52 Go to previous messageGo to next message
David,
It sounds to me like a URI should have been used in the first place. Is
it clear whether an entry in the catalog is supposed to be a file system
path verse a URI. Characters like \ can occur in file system names on
Linux, i.e., they're not path separators in a URI, URL, nor in Linux
file system paths, so treating them with the assumption that they are to
be converted to /, is not entirely correctly. I wonder if specifying a
URI, i., file:/C:/Documents%20and%20Settings/username/.m2, would have
made it work in the first place? I wonder if this is supposed to denote
a file or a folder? In the latter case,
file:/C:/Documents%20and%20Settings/username/.m2/ would have been better...
Certainly the entry processing could be more friendly and do obviously
conversions, such as turning space into %20, but turning \ into / is
more dubious...
> correctly encoded so that spaces are converted to %20.
>> the file resides in the local Maven repository on a Windows machine.
>> The path the local Maven repository included both spaces and a '.'
>> character:
>> file location with no spaces or '.' character which worked correctly
>> in the dialog for entering an XML Catalog entry in Eclipse.
Re: XML Catalog Question [message #225538 is a reply to message #225522] Sun, 21 December 2008 14:06 Go to previous message
Ed Merks wrote:
> David,
> more dubious...
Correct...however, if going through the user interface of the XML
Catalog in WTP it should store that information as a URI so that it gets
converted. I'm not sure it is actually doing or that the platform
URL/URI items are completely compliant.
I remember a big discussion in the platforms URI handler where some
encoding was not happening correctly and this was causing issues. If
you encode as a URI even under windows the \ get converted to a /
otherwise it isn't a correct URI.
Previous Topic:no XML object
Next Topic:SSL Connection timeout with Tomcat 5.5.x & 6.x started from Eclipse 3.4
Current Time: Wed Jul 23 12:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.10622 seconds
