Connection Anchor [message #225311] |
Mon, 30 October 2006 08:37  |
Originally posted by: mounafeki.yahoo.fr
I would like to define specific Connection Anchor for a Figure so that I
can connect my Figure only from these points.
I wanted first to take the example logic as a sample . But it was very
complicated and I have got wrong results (see my mail of 27.10 : Problem:
FixedConnectionAnchor).
which single steps (generally )must i follow to have the desired results?
Which Classes must i costumize?
Please i want your Help!
Thanks in Advance.
Re: Connection Anchor [message #225355 is a reply to message #225311] |
Mon, 30 October 2006 11:42   |
在 2006-10-30一的 13:37 +0000,Mouna写道:
> Thanks in Advance.
from statement before, there are 2 point A,B, and A for input just be
target anchor, B for output just be source anchor.
so this story get a right result, two connection from B output, not A
input. if A, it should not correct.
So you have no problems, just need a design: which for input, which for
output.
Hope I get you.
Qinxian.
Re: Connection Anchor [message #225433 is a reply to message #225404] |
Mon, 30 October 2006 22:50   |
在 2006-10-30一的 21:08 +0000,Mouna写道:
> Hi Qinxian,
> rear, perhaps you do not have my problem so well understood. For the
> figure i would like define 2 Anchors Points A and B. A and B are output as
> input Anchors at the same time. I.e. my goal is: If I connect Figure
> GleisSegmentFigure as SOURCE with other Figure X , then I can
> select/choose A or B as output points. And If I connect Figure
> GleisSegmentFigure as Target with other Figure X , then I can
> select/choose A or B as input points.
> ---> I would like that Figure GleisSegmentFigure a several output and Input
> Anchors have. How can I realize that?
> Thanks
> Mouna
just like logicdesigner, there can have a list for anchor terminals.
As long as the EditPart get a right Anchor, no matter little or few,
that's it.
Qinxian
Re: Connection Anchor [message #225464 is a reply to message #225456] |
Tue, 31 October 2006 04:04   |
在 2006-10-31二的 08:33 +0000,Mouna写道:
> Hi Qinxian,
> Could you please explain the steps to define Anchor points. Whhich
> classes or methods schould i insert or customize? The Logic example is
> very complicated Thanks
> Mouna.
Depends on your design. if model need these anchor info, add into it.
Generally can declare integers or strings in model as anchor terminal,
but no matter how, should not declare GEF Anchor class in model.
then get anchors by given terminal, just like your code.
if model need not, just put these anchor info into editpart or figure.
then get anchors directly from editparts or figures.
GEF concert with getSource/TargetConnectionAnchor(...) methods.
regarding to how to provide these anchor, GEF don't take care of it.
if logic example others is complicated, its Gate class and GateEditPart
should be a simple case, pay more attention to it.
Qinxian
Re: Connection Anchor [message #225513 is a reply to message #225505] |
Tue, 31 October 2006 06:50   |
在 2006-10-31二的 10:53 +0000,Mouna写道:
> We assume that I would like to change the Schapes Diagramm Code so that I
> may connect a rectangle only from the two upper corner (See Picture)
> A X---------X B
> Which Methods and/or Classes schould i customize? And How?
> Thanks
> Mouna
You can only handle this EditPart class, and implements all methods in
NodeEditPart inteface.
>From method name we know get*Anchor(Request) used for editor actions,
for example click figure, and dragdrop to another figure.
And get*Anchor(ConnectionEditPart) used for updating the figure and
draw.
Detailed anchor selection depends on designed model,for example,
database table foreign key connection, modeled ForeignKey with id, fk
members,
get*Anchor can perform a rule,
ForeignKey fk= connection.getModel();
if (fk.id=getModel().id) return anchorA,
if (fk.fk=getModel().id) return anchorB.
according to get request anchor, can do with samelike way.
As you known, my english is more strange and laughed, of cause, I'm a
china. my english is not brilliant as my china.:)
But if you have question, I would be happy to give a hand as possible.
Qinxian
Re: Connection Anchor [message #225536 is a reply to message #225521] |
Tue, 31 October 2006 07:37  |
Mouna 写道:
> I would have used this method if I had 2 kinds of connections. Then I
> would have defined Anchor A for type Connection1 and AnchorB for type
> Connection2. But I have only one single kind of connection. And I would
> like to connect my Figure (means of this connection) of A as well as of B.
> Regards
> Mouna
Which anchor depends on user operate result, he can select A or B as a
anchor. if handler this, model need a anchor terminal info.
Letter above refer a model without anchor info.
Qinxian
FUDForum. Page generated in 0.03759 seconds
