Home » Eclipse Projects » GEF » Create a Label for a Figure
Create a Label for a Figure [message #225213] Thu, 26 October 2006 06:55 Go to next message
Originally posted by: mouna.feki.siemens.com
I would like to insert a Label (content the Name of the FigureX) to a
FigureX (like in the case of an Edge).
My aim is:
Label and Figure stand separately, i.e. I can (independently of
the Figure) select and put anywhere the Label.
Does anybody have an idea to solve this Problem?
Or there are an Example ?
Mouna
Re: Create a Label for a Figure [message #225220 is a reply to message #225213] Thu, 26 October 2006 13:14 Go to previous messageGo to next message
在 2006-10-26四的 10:55 +0000,Mouna 写道:
> My aim is:
> Thanks
> Mouna
Maybe that you create a suite parent-child editparts, and make a kind of
layout, is a not bad idea.
Qinxian
Re: Create a Label for a Figure [message #225222 is a reply to message #225220] Thu, 26 October 2006 17:06 Go to previous messageGo to next message
Has you an Example, because i am new in GEF Domain?
Mouna
Re: Create a Label for a Figure [message #225255 is a reply to message #225222] Fri, 27 October 2006 12:15 Go to previous message
在 2006-10-26四的 21:06 +0000,Mouna写道:
> Thanks
> Mouna
There is a good example, gef logic.
you can refer to diagram container with xylayouteditpolicy, and
customize LogicContainerFigure to your figure style , and
LogicContainerEditPart to your editpart which only having a child just
be figure's label.
Qinxian.
Previous Topic:Problem: FixedConnectionAnchor
Next Topic:This command is executed
Current Time: Mon Jun 02 23:32:06 EDT 2025
Powered by FUDForum. Page generated in 0.05345 seconds
