Home » Language IDEs » ServerTools (WTP) » Maven jars but publish locally but are copied into exported war file
Maven jars but publish locally but are copied into exported war file [message #224978] Fri, 12 December 2008 08:14 Go to next message
I'm having a problem with the latest WTP in Ganymede and an existing
project originally set up with a previous version.
The project refers to jars in a local Maven repository via extensions of a
"MAVEN_REPO" classpath variable as follows:
<classpathentry exported="true" kind="var"
path="MAVEN_REPO/spring/jars/spring-1.2.6.jar">
<attributes>
<attribute name="org.eclipse.jst.component.dependency"
value="/WEB-INF/lib"/>
</attributes>
</classpathentry>
MAVEN_REPO is set to C:/java/maven-repository in Preferences -> Java ->
Build Path -> Classpath Variables.
I have ticked all the checkboxes in the project's "Java EE Module
Dependencies" tab but the jars are not copied to
" workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp 0\wtpwebapps\pa-web\WEB-INF\lib ".
It seems like configuration for what get published locally has changed
between WTP versions from ${project}\.settings\.component to
${project}\.classpath (as shown above). I have removed the old entries
from the .component file. Are there any other old artifacts lurking around
that might mess this up?
I found this wiki page, but it seems like overkill to have to define a
"User Library" just to get the jars deployed locally given that they are
already on the project's build path:
http://wiki.eclipse.org/ClasspathEntriesPublishExportSupport
If I "Export..." as "web/WAR File" the jars are included in the war file
in the right place.
Has anyone had the same problem? Any ideas on how to resolve the problem?
My set up is:
Eclipse 3.4.1 (and the WTP that comes with it)
Maven 1.0.2
Tomcat 6.0.18
JDK 1.6.0_10
Thanks.
Ashley
Re: Maven jars but publish locally but are copied into exported war file [message #224986 is a reply to message #224978] Fri, 12 December 2008 08:15 Go to previous messageGo to next message
Meant to say "Maven jars _not_ published locally but are copied into
exported war file"
Re: Maven jars but publish locally but are copied into exported war file [message #225001 is a reply to message #224986] Fri, 12 December 2008 09:18 Go to previous messageGo to next message
> exported war file"
I created an equivalent entry for a jar in a test dynamic web project
and the jar published fine. You can try right-clicking on the server
and selecting "Clean..." which will avoid "delta" publishing (in case
the delta is being computed incorrectly) and force a full publish. I
doubt this will fix it, but it's not clear what is different that is
causing the jar not to publish for you.
Larry
Maven jars _not_ published locally but are copied into exported war file [message #225009 is a reply to message #224986] Fri, 12 December 2008 09:18 Go to previous messageGo to next message
(updating subject)
Re: Maven jars not published locally but are copied into exported war file [message #225017 is a reply to message #225001] Fri, 12 December 2008 09:26 Go to previous messageGo to next message
Hi Larry,
Thanks for the response. I've tried a "Clean..." and a republish but the
problem is still there.
Just noticed something. The main project's two project dependencies are
deploy as jars correctly (as specified by the tick boxes on the "Java EE
Module Dependencies" tab. It's only classpath variable based one which
aren't published.
Cheers.
Ashley
Re: Maven jars but publish locally but are copied into exported war file [message #225025 is a reply to message #225001] Fri, 12 December 2008 09:33 Go to previous messageGo to next message
>> exported war file"
> Cheers,
> Larry
I've tried creating a project from scratch and adding a jar based on
MAVEN_REPO and it is indeed published (as you said).
I'll see what differences I can find between the two project's configs.
Re: Maven jars but publish locally but are copied into exported war file [message #225033 is a reply to message #225001] Fri, 12 December 2008 10:35 Go to previous message
I've created an empty Dynamic Web Project and copied the files from
settings. I've upgraded my web.xml to spec 2.5 and everything is now
working.
Must have been my old/inconsistent config. Thanks for the help.
Previous Topic:Tomcat 5.5 startup detection
Next Topic:Jars for running dynamic web app
Current Time: Fri Jul 18 18:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.08546 seconds
