Home » Eclipse Projects » GEF » Display diagram title
Display diagram title [message #224655] Tue, 17 October 2006 21:15 Go to next message
Originally posted by: novs.gmx.net
My gef editor supports two different views of the model by using
setContents(). Is there a way to display a label in the top left corner of
each diagram ? I tried getFigure().add() in the diagram editpart but it
didn't work.
Thanx
Rick
Re: Display diagram title [message #224663 is a reply to message #224655] Tue, 17 October 2006 21:46 Go to previous messageGo to next message
Originally posted by: sundaolin.126.com
What is the layoutManager of the figure?
If its a freeformlayout,then you should not only call the
getFigure.add(),but also the
getFigure().setConstraint(figure,constraint);The parameter figure here
is the title you want,it may be a Label or other figure you like.
you can also use the titlebarBorder,but it seems that the title is on
the top of the figure,not the top left.
Rick Markov 写道:
> Hi
> of each diagram ? I tried getFigure().add() in the diagram editpart but
> it didn't work.
> Thanx
> Rick
Re: Display diagram title [message #224743 is a reply to message #224663] Wed, 18 October 2006 16:04 Go to previous message
Thanks, that did it :)
Previous Topic:How to put a TextField in a ToolBar?
Next Topic:GEF for text editing
Current Time: Sun Jul 27 11:13:02 EDT 2025
Powered by FUDForum. Page generated in 0.24921 seconds
