Home » Eclipse Projects » GEF » Problems with gradients in rounded rectangles
Problems with gradients in rounded rectangles [message #224030] Wed, 11 October 2006 06:03 Go to next message
Originally posted by: mateu.yabar.justinmind.com
Im trying to draw a figure which is a roundedPanel that its background is a
gradient; there fore I'm reimplementing the paint methods.
I've tried to use the method fillGradient to fill the backround, but this
method can only use a rectangle, so the rounded corners will also be
painted.
Afterwards I have tried to use the method setBackgroundPattern but I'm
having much trubble. I hace tried the following:
But after using this all the drawings go crazy (among others, a lot of
figures are drawn using the gradient).
I've tried the following lines:
Pattern pattern=new Pattern(null, 150,0,300,0,ColorConstants.blue,
ColorConstants.yellow);
((SWTGraphics)graphics).setBackgroundPattern(pattern);
graphics.restoreState();
Which I spected to do nothing (the beckround pattern shold be the original)
but it continues drawing thins in gradient.
I'm using GEF 3.1.1.
Re: Problems with gradients in rounded rectangles [message #224426 is a reply to message #224030] Mon, 16 October 2006 05:41 Go to previous messageGo to next message
在 2006-10-11三的 12:03 +0200,Mateu Yábar Vallès写道:
> painted.
> Thanks
You can refer to ajdt visualizer source code, which has a paint gradient
header way that could satisified your requirements.
QinXian.
Re: Problems with gradients in rounded rectangles [message #224565 is a reply to message #224426] Tue, 17 October 2006 03:18 Go to previous messageGo to next message
I'll look the source code.
Thanks!
"xiangqinxian" <fyaoxy@gmail.com> escribi
Re: Problems with gradients in rounded rectangles [message #225054 is a reply to message #224030] Tue, 24 October 2006 11:59 Go to previous message
Originally posted by: none.ibm.com
If the gradient does not change too much, you can ignore the rounded areas
and only perform the gradient in the middle section.
There is a bug related to patterns in 3.1.x. There is also a workaround. I
think the bug was that we copied and pasted code and we were checking FG
instead of BG. Search bugzilla for the fix and a possible workaround.
However, advanced graphics support is much better in 3.2 version of SWT,
plus you get the GEF fix too.
"Mateu Y
Previous Topic:To slow scrolling with ScrollPane
Next Topic:Question about connection. How can I do this?
Current Time: Wed Jul 23 18:18:03 EDT 2025
Powered by FUDForum. Page generated in 0.04601 seconds
